Results 1 to 5 of 5
    Aug 09 2018
    New Zealand
    Slave cylinder rod popped out
    depressed the clutch petal when the motor wasn’t in, don’t ask me why..
    The rod has popped out of the cylinder and lost all fluid. Took it off and I can’t get the rod back in to save my life.
    Any help here would be appreciated
    Thanks guys
    Jan 01 2018
    utah
    Have you opened the bleed screw and tried to push the rod in? Usually, there is still some amount of pressure in there when you're pushing the plunger back in.
    Sent from my SM-S928U using Audizine Forum mobile app
    Aug 09 2018
    New Zealand
    I can’t get that actual rod to press back into the metal cylinder that sits on the spring.
    Jan 01 2018
    utah
    Doesn't it just rest on the plunger? Did the boot come off?
    Aug 09 2018
    New Zealand
    The boot didn’t come off but oil came pissing out
