Page 3 of 3 FirstFirst 123
Results 81 to 112 of 112
  1. #81
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Build List so far!!
    O1E JHM rebuilt 6 Speed
    KO4's with Melett Cores
    AWE intercoolers
    710N Diverter Valves
    Full Engine Reseal
    Bosch 550cc injectors
    NGK Iridium Plugs
    RS4 airbox with MAF
    RS4 inlet pipes
    SSAC downpipes
    034 blockoff plates
    A4 Wheels
    B8 Q5 Brembo front brakes
    D3 S8 rear brakes
    034 throttle body boot upgrade
    JXB driveshaft support
    3D
  2. #82
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    And Tuned by STUKLR!!!!!!!!
    3D
  3. #83
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Quote Originally Posted by Dmoore016 View Post
    Build List so far!!
    AWE intercoolers
    Full Engine Reseal
    NGK Iridium Plugs
    RS4 airbox with MAF
    RS4 inlet pipes
    SSAC downpipes
    034 blockoff plates
    A4 Wheels
    D3 S8 rear brakes
    And TTV Flywheel with RS4 Clutch
    3D
  4. #84
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    My current situation with ECS. I ordered a water pump that was supposed to come with a metal gasket 2 months ago. Part arrived and had a paper gasket that was ripped in half. No big deal things happen. I however contacted them twice before placing the order to verify. I called customer service and yet again they verified it was supposed to come with a metal gasket and said they would provide one as soon as they got the part number. That was the last time I heard from them on the gasket. I also ordered a fan blade , same deal confirmed fitment part showed up in the right label package but it is for the 1.8 engine. called in and got label for return and then double confirmed fitment so I could get the correct one out. second fan sent same deal 1.8 fan. I called last Friday to speak with a Manager to get this taken care of. No mangers were available and was told I would receive a call back shortly. NO one has called or emailed from ECS. As a Parts Manger myself this is hard to swallow, customer service and customer experience are key. just my 2 cents
    3D
  5. #85
    Feb 05 2007
    Portland, OR
    Due to this very dynamic with ECS, I don’t play with them anymore. It really is a game, it feels like. I’m sorry you’re experiencing this. EuropaParts is where I got my fan blade and they also have Hepu water pumps and the ability to buy a kit with only the components you want.
  6. #86
    May 20 2010
    I can confirm ECS is slow to respond. I emailed them right after placing an order (and 3 days before it shipped) and they did not respond until the day after it shipped. FCP is much more responsive.
    I find myself using ECS for research due to the usually good pictures they have.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
  7. #87
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Been driving this beast all around getting the miles in got about 350 miles to go then I can start 100% boost logging..
    3D
  8. #88
    May 09 2012
    Virginia
    The TTV flywheel and RS4 combo is such a great setup! Have run in it on multiple cars. Have another one of these combos ready to go for my build when it happens.
  9. #89
    Feb 05 2007
    Portland, OR
    Very nice!
    What is the break-in period recommended for this setup?
  10. #90
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Quote Originally Posted by ShelbyM3 View Post
    Very nice!
    The recommended break in for the Mellett cores is 500 miles
    3D
  11. #91
    May 09 2012
    Virginia
    Quote Originally Posted by Dmoore[emoji[emoji6[emoji640
    ][emoji6]][emoji6];[emoji6][emoji[emoji6][emoji6]][emoji[emoji6]][emoji6]]The recommended break in for the Mellett cores is [emoji6][emoji[emoji6][emoji6]][emoji[emoji6][emoji6]] miles
    Sent from my iPhone using ]][emoji[emoji6]][emoji6][emoji[emoji6]][emoji6]]Audizine Forum
    That’s the same for the clutch as well.
  12. #92
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Got about 250 miles on the car so far car is running well. Had a leaky driver side out CV boot, installed a new half shaft yesterday. On Sunday the heat started blowing out luke warm air, so it looks like a heater core back flush is in store. Did some reading sounds like a common issue. Has anyone else experienced this issue?
    3D
  13. #93
    Feb 05 2007
    Portland, OR
    Yeah, a lot of us. It’s the cast iron blocks fault. If you want to look at my “My Third AR…” thread, I document how I did it this last summer. I got a garden hose adapter off Amazon and some big clear tubing so I could see what was happening. Helped, but ultimately I’ll need to replace my heater core. I grabbed 2 Nissens from FCP when they went on clearance. Crazy part is, the hardware needed, which is 2 metal clamps with a little screw that tightens them almost like a v-band, is just as expensive as the heater cores.
  14. #94
    May 20 2010
    Ugh, I hated replacing the heater core. Be careful on the kit you get--I got a Nissens kit and the o-rings were wrong and prevented me from installing it until I got the correct OE o-rings.
    When I got my car, I did the CLR flush, which definitely helped a lot for a couple years. Of course, someone had sludged it up by putting green coolant in with the pink and so it was all kinds of nasty.
  15. #95
    May 09 2012
    Virginia
    The clamps also make a difference. I’d get genuine clamps and o-rings if you can. It’s a bit of a pain to change and you’ll need to put down some sort of trash bag to catch the fluid that leaks out of the core when you undo the clamps and pipes. But at least you don’t have to remove the whole dash like you do in the B5’s.
  16. #96
    May 20 2010
    I was reusing my original clamps. The clamps were fine--it was def the o-rings being too thick, since after I eventually towed it to the shop to do b/c I had to go on travel, they got original o-rings and had no issue.
    Amen to this!
  17. #97
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Thanks guys I will attach pics this weekend of all the goodness I flush out and go from there.
    3D
  18. #98
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Heater core back flush was a success, bunch of small rust particles came out not really anything to get pictures of. I used air and water to do it . Nice warm heat flowing now on this beautiful 7 degree day.
    3D
  19. #99
    May 20 2010
    Happy you were able to restore heat in that balmy weather
  20. #100
    Feb 05 2007
    Portland, OR
    Nice job! Having heat at idle is so taken for granted.
  21. #101
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Got about [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] miles on her so far. all is well loving the [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]] speed and at about [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] rpm WAHOOOOOO starts to come on. I’ve been nice and easy so far [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] more miles to go and I will start boost logging hopefully the temps will be back up out of the teens by then. Totally digging this platform
    Sent from my iPhone using [emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]]]Audizine Forum
    3D
  22. #102
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Sorry about all the emojis above something is wrong with the app
    3D
  23. #103
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Got [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] miles on the car so far. All is well and loving the [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]]] speed at about [emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6][emoji6]]]][emoji[emoji6][emoji6]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]]][emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] rpm WAHOOOOOO starts to kick in. I’ve been nice and easy on her so far got about [emoji[emoji[emoji6][emoji6]][emoji[emoji[emoji6]][emoji[emoji6]]]][emoji[emoji[emoji6]][emoji[emoji6]]][emoji[emoji[emoji6]][emoji[emoji6]]] more miles then I will start boost logging hopefully temps will be up out of the teens by then. I’m loving this platform and looking forward to the next steps
    3D
  24. #104
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    I will update the post from my computer the app is not working
    3D
  25. #105
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Got about 300 miles on the car so far, all is well loving the 6 speed at about 4200 rpm WAHOOOOOO starts coming in!!!!!! I’ve been gentle on her so far. Got 200 more miles to go and then I can start boost logging hopefully temps come up out of the teens. Loving this platform and looking forward to what’s next!!!
  26. #106
    Junior Member Two Rings
    Jan 09 2025
    Wake Forest, NC
    On your JHM trans rebuild did you send them a random core or your core, or have a local shop rebuild it? I have a stage 3 A6 that needs one so I am weighing options.
  27. #107
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    Quote Originally Posted by SleeperA6 View Post
    It was rebuilt using JHM parts by the guy I purchased my 6speed swap from
    3D
  28. #108
    Jun 10 2024
    Jetta, Old C1500
    Midwest
    The allroad is performing well about 1,000 miles on it so far. The only issue at the moment is the aftermarket so called upgrade Throttle body boot. Not impressed keeps blowing one pipe off. Maybe I have a lead foot. Stock boot in route now
    3D
  29. #109
    Oct 01 2024
    lansdale, pa
    I have been using 034 boot and hasn’t blown off yet 26psi on eThe clamps are good just have to tighten them well
  30. #110
    Jan 09 2025
    Wake Forest, NC
    It took me an afternoon to fit mine and get it oriented right so it would seal the map sensor o-ring correctly and hold both bi-pipes properly, I had one blow off during a pull and I about turned my shorts brown.😁 I am also running t-bolt clamps on those 3 connections.
  31. #111
    Oct 31 2022
    Prescott AZ
    Make sure you remove all the parts. Clean all the surfaces with brake clean. Even the outside where the clamp goes. And it will solve your problems.
    The map sensor fitting correctly is a pain tho.
    The metal throttle body from the late allroad is by far the bed solution to this!
  32. #112
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Metal throttle body from 2005 allroad is the second best solution.
    APR bi-pipe is the best:
