Results 1 to 6 of 6
    Oct 14 2006
    by the lakeshore, mi
    Rear shock hardware help please.
    I'm having troubles finding the part numbers for the nuts and bolts for the upper and lower shocks for the rear and the nut and bolt for the rear outer-upper control arm. Also the four bolts for the rear shock mount that's attached to the body. Anyone have these part numbers?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Oct 14 2006
    Thanks! I see that the lower shock bolt and the upper shock bolt have different part numbers but are listed at the exact same size of M12X1,50X85. So why two different part numbers?
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    Quote Originally Posted by speedydtp247 View Post
    No difference really today. Could have originally been some minor difference (flat vs pointed tip of the bolt as just a random example). Looks like both are currently using part N10241202.
    https://www.ecstuning.com/b-genuine-...ach/n10241202/
    Sent from my SM-F741U1 using Audizine Forum mobile app
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    I believe the shoulder is different between the 2
    May 10 2018
    MA
    Quote Originally Posted by Silverex View Post
    Correct
