Results 1 to 2 of 2
Thread: P1287 Help?
    May 04 2020
    PA
    Question P1287 Help?
    As title states, I have a CEL for P1287(static, open circuit). Car had a ton of cels when I got it but I’ve been fixing things, can’t seem to track this one down though.
    Ohmed out the N249 and it seems within spec. Some forum posts said 28-30ohms, mine was reading 25ish. Voltage to the connector was 11.5v. Fitting a new DV on tomorrow and I might as well pressure test the N75. Anything else to look at? Most of what I read has said it’s an issue with the N249. Car has no boost under ~2300rpm and once it spools it’s still slow. Bone stock.
    Established Member Two Rings Danisson's Avatar
    Dec 30 2023
    Cluj, Romania
    Been working these days on the N112 and N249 solenoids (same part by the way); freshly painted the mounting plate, cleaned and polished the solenoids themselves, new screws, new silicone vac lines and all that great stuff. (post incoming ;) Measured their impedance while I was at it and both were ~ 28-29 Ohms.
    To diagnose a faulty N249 though, run a vacuum line form your DV straight to the intake manifold where your N249 gets its vacuum from. Loop the N249 nipples with a line and see how the car behaves.
    '02 A4 B6 1.8T 5-MT | ECM Tune | Res Delete & 4" Chrome Tips | MTS Technik | USP Front Bumper & Trunk Lid | S4 Door Blades & Sills | 18" ET43 USP Alloys & Continental "SportContact 6" | Black DEPO E-codes & Smoked Side Markers | Blacked Out Grilles | Glovebox Fridge | Color DIS | Brushed Aluminium Trim | RNS-E PU (mkII) & 6 CD Changer | Auto-Dimming & Compass and more...
    "Dani"
