As title states, I have a CEL for P1287(static, open circuit). Car had a ton of cels when I got it but I’ve been fixing things, can’t seem to track this one down though.
Ohmed out the N249 and it seems within spec. Some forum posts said 28-30ohms, mine was reading 25ish. Voltage to the connector was 11.5v. Fitting a new DV on tomorrow and I might as well pressure test the N75. Anything else to look at? Most of what I read has said it’s an issue with the N249. Car has no boost under ~2300rpm and once it spools it’s still slow. Bone stock.
