just had my brake pad warning come on today; haven't taken the wheels off to check if it's a loose wire, if it's a glitch, or if the pads are actually low.
Car has 75k miles on it, 2016 RS7 Performance with ceramic rotors
given the cost of the rotors, i assume you don't need to change the rotors with the pads.
OEM pads run ~1k USD for fronts, another 1k for rears, roughly. Is there any other solution than OEM? and if so, any links, or part numbers?
