Results 1 to 4 of 4
    Established Member Two Rings caelric's Avatar
    Jun 10 2023
    Colorado Springs, CO
    2016 RS7 Performance Ceramic Rotors: What pads?
    just had my brake pad warning come on today; haven't taken the wheels off to check if it's a loose wire, if it's a glitch, or if the pads are actually low.
    Car has 75k miles on it, 2016 RS7 Performance with ceramic rotors
    given the cost of the rotors, i assume you don't need to change the rotors with the pads.
    OEM pads run ~1k USD for fronts, another 1k for rears, roughly. Is there any other solution than OEM? and if so, any links, or part numbers?
    2016 RS7 Performance - Prism Silver Crystal - Comfort/Bang & Olufsen - DS1 Stage Custom 1 w/ BTRes- TGK Intake - 034 Suspension/Transmission/Differential Inserts
    Junior Member Two Rings
    Mar 31 2011
    denver
    Same question from me!
    According to this thread: https://www.audizine.com/forum/showt...rformance-2016
    ...the Brembo pads work, about $100 for fronts and $100 for rear.
    Front, Brembo: P85175N
    Rear, Brembo: P85151N
    (I'm up in Denver, Colorado, hit me up if you find a shop to do it!)
    Jun 10 2023
    i'm not sure those brembo pads work, i think those pads are carbon ceramic, yes, but not for the carbon ceramic rotors.
    turns out i don't need them, it was just a brake sensor wire that got cut rather than anything wrong with the pads or rotors.
    as for changing pads, i'd have no problem doing it myself if it were necessary; i do most of my own work on my RS7P.
    Junior Member Two Rings Sla's Avatar
    Nov 22 2023
    odessa ukraine
    the official representative of Brembo replied that the articles are correct
