Results 1 to 8 of 8
    Nov 11 2024
    Trenton, NJ
    Misfire and hard start
    Hi, I'm new to the forum. My son has a 2015 A3 2.0t premium plus. It has a random misfire under load. It's usually right after it shift into 2nd or 3rd around 2000rpm, give or take. It'll misfire a few times but go away if you continue to accelerate. I work on heavy trucks and have a heavy truck scanner. I was able to check codes with it and no active or inactive codes are set. When I look at the misfire parameters all four cylinders show 3 or 4 misfires on the last drive cycle. My son also said that intermittently he has a hard start condition (I have not experienced the hard start). It's very intermittent but seems like it only happens when the engine is warm. Has anyone had similar issues or any ideas what might be causing this?
    Matt
    Veteran Member Four Rings MikTip's Avatar
    Dec 25 2004
    Earth
    Quote Originally Posted by Matthew Eckel View Post
    Matt
    Miles? The first thing people often do is change spark plugs and or coil packs...
    2015 S3 with 210,000 miles. New 2019 Q5 motor. Still going!
    Nov 11 2024
    Trenton, NJ
    170,000 miles. Plugs and coils were changed about 6 months ago.
    Nov 11 2024
    Trenton, NJ
    Thanks for that MikTip. Very useful information!
    Dec 25 2004
    Earth
    Has the engine been carbon cleaned?
    Nov 11 2024
    Trenton, NJ
    It has not. I'm debating whether to buy a fuel pump, an OBD11, or take it to a shop that I don't trust to have the carbon cleaning done.
    Sep 22 2011
    Western MA
    I would do a compression check and look around with a bore scope before spending time or money on a carbon cleaning.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
