Results 1 to 13 of 13
    Established Member Two Rings jpjmustang's Avatar
    May 23 2013
    2014 Audi Q7 TDI - 2011 BMW 328I
    Missouri
    2012 3.0T Timing Chain Replacement - Input? (P0018)
    Have a reoccuring code P0018 - changed the Cam position sensors / Crank position sensor and checked the VVTs (ok)
    still threw code - took to Audi - they pulled cam covers and determined that the drivers side cams are out
    Looking at chain replacements - looks like a HUGE job pulling the engine to work them on the back of the engine
    ASK : (1) are there any tricks / pointers to pulling engine? (2) what would you replace while you have the engine out?
    the kits are varied out there .......
    JPJM
    [B]JPJMustang[/B]
    2014 Audi Q7 TDI 3.0 Prem +
    2012 Audi A6 3.0T Prem +
    2011 BMW 328i
    2004 BMW X3
    Established Member Two Rings SaVAGeSoot's Avatar
    Sep 30 2024
    K-W, ON, Canada
    Sounds like a potential tensioner issue.
    Are you sure you have to pull the motor? I'm almost certain that you only drop the tranny to get access.
    What does the service manual tell you?
    2014 A6 TDI Technik S-line
    May 23 2013
    Missouri
    I saw on line - that one process is to pull the motor out the front - the other shows working it with the tranny pulled.
    Didn't know if you had enough room with the Tranny pulled to get all the "marks correct.
    What do you think?
    [B]JPJMustang[/B]
    2011 BMW 328i
    2004 BMW X3
    Sep 30 2024
    K-W, ON, Canada
    I think you need to reference the service manual.
    Established Member Two Rings NorthernGTI's Avatar
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    Quote Originally Posted by jpjmustang View Post
    What do you think?
    Alldata says to remove transmission.
    2014 TDI
    May 23 2013
    Missouri
    Thank you - did look in the manual
    BUT other persons call for the engine pull - most of the comments were - If you doing chains, etc, pull the engine and do other items such as engine mounts, etc.
    Just looking for advice from someone who has "experienced the pain"
    Also - where did you buy your kit from?
    JPJM
    [B]JPJMustang[/B]
    2011 BMW 328i
    2004 BMW X3
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    VAALLLLLLLPOOOOO!
    Wish you could tag folks on here.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Sep 30 2024
    K-W, ON, Canada
    Quote Originally Posted by NorthernGTI View Post
    OP won't have it.... they'd rather start off with a 13.5h procedure.... probably has a shop with cheap rates!
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Quote Originally Posted by Burkeomatic View Post
    VAALLLLLLLPOOOOO!
    You rang?
    I am no longer in the Audi ownership rank and file but still come back here to hang out online. DON'T miss wrenching on the A7 at all.
    Step 1, consider trading the damn thing off and replacing the vehicle. You are gonna drop a lot of coin into fixing the car that is already 12 - 13 years old.
    Audi dealer will be the most expensive if you pay to have it done.
    Indie shop will be $5,000 to $6,000
    Home repairs - you will spend probably at least $2000 plus specialty tools.
    Regarding P0018. Normally I would say clean the sensors bank 1 and 2 and see if that helps then switch left to right. But seeing that the Audi dealer already pulled the timing covers and confirmed damage then yep time to do at least the upper tensioners. The uppers can be done without removing the engine but its gonna be tight to work.
    https://www.youtube.com/watch?v=ZAWsKChptvU This covers the repair with the engine still in the car for replacing the uppers. The vid is for a 3.2 but its pretty much the same.
    I did not see anything other than OEM for the tensioners but you can get IWIS chains rather than OEM. From what I found IWIS is the OEM supplier. You will need to pull the motor if you are changing the chains as well. 4 chains and 4 tensioners and a lot of bolts to replace per the Erwin manual. Internal bolts I would change out, external bolts that is up to you, the dealer is supposed to change them for warranty reasons.
    If you decide to replace all 4 chains and tensioners then you have 2 routes. Disconnect the engine and part of the subframe and drop it out or take off the nose of the car and pull it out the front with the trans and then disconnect them once out.
    A few pictures from when I did mine. As you can see in pic #4 a chain was loose and chewing on a tensioner.
    Feb 22 2021
    San Antonio
    Quote Originally Posted by Valpo A7 View Post
    You rang?
    I was going to suggest he give just the top chains a shot if he wants to try to doit with the engine in the car.
    That said, half the time I try a shortcut like that, I feel like half the time it would have been easier had I just done it "the long way."
    Referring to your step 1, that's why I decided to go ahead and get a V8. I figured if I'm going to maintain a car like this, it may as well be exactly what I want.
    Nov 27 2018
    Valparaiso, IN
    Someone posted over on Audiworld to remove the SC to gain more working room if you tackle the tensioners with the engine still in the car.
    May 23 2013
    Missouri
    Thank you - follow up question
    VALPO A7 - thank you for your responses
    Thought this was going to be painful
    JPJM
    Recommendation - If Im going to keep the car - who would you buy parts from? - if not keeping - who would you buy from (ECS, Dealer, etc.)?
    [B]JPJMustang[/B]
    2011 BMW 328i
    2004 BMW X3
    Nov 27 2018
    Valparaiso, IN
    ECS or FCP Euro if you are gonna fix this yourself. If you are going to use the credit card wrench then talk to the shop to see if you can provide parts, some shops will not install customer parts for their warranty reasons.
    For the tensioners I think you are stuck with getting OEM, never saw a source for NON-OEM.
    For the chains I went with IWIS and was told by ECS or FCP that they actually supply the OEM chains.
    Some while its in the shop ideas to consider:
    New gear oil for both diffs and the transfer. Synthetic GL-5 works. Even in the transfer. Factor fill on the transfer is some special and expensive juice that is GL4 with an additive. GL 5 works fine. Put 34,000 miles on it with no issues.
    Give the motor mounts a good look, perfect time to change them.
    Consider changing supercharger oil
    Consider replacing both belts
    Consider a new PCV
    Be prepared to break the PCV hose.
    Disconnecting all the coolant lines can be a pain but a shot of WD40 will make it easy.
