Selling a 2003 epl stage 3 allroad. VIN WA1YD64B13N003058 Atlas grey 129k. Pretty sure turbo's are BLOWN. The following work was done 10k miles ago. Engine from an S4 put in(about the same mileage). Original motor snapped rod because plugs weren't gapped. New borg warner chras, gates racing timing belt kit with all seals including front and rear main seals. Oil pan gasket NOT replaced. Powder coated black valve covers and intake manifold. Ngk bkr6e gapped to .026. About a year ago turbo's started whining and was burning oil out of exhaust. Parked the car in the garage since. Occasionally pull it out. Turbo's seem to have stopped spooling. Don't have the time to pull the motor again. Asking $5500. Will post pics once I figure out how.
Mods
Epl stage 3 tune
Epl 85mm maf
550cc injectors
Bw k04s with oem rs4 inlets
Apr bipipe
Sidemount ic not sure of brand
Ar design 3" down pipes
Magnaflow cat back
034 street density mounts
Fidanza lwfw
Vast rs4 clutch
Arnott bags all around
Hotchkiss front and rear sway bars
034 sway bar links
Jhm short shifter
Known issues
Blown turbo's
Cel on for sai. (S4 engine doesn't have)
Tranny has a slight whine in lower gears (1,2)
Dent in driver side fender
Rust bubble on hatch ( have an extra hatch)
Suspension clunks over bumps. Control arms?
Coolant crossover pipe has a leak at gasket.
