Results 1 to 3 of 3
    Junior Member Two Rings
    Jul 10 2024
    Fluid maintenance trans diff front diff
    Trying to change all fluids . Only had vehicle for 2 months 2015 rs7. What do I need front diff fluid. Trans fluid. Rear diff fluid.
    How much of each and recommended brands for each thank you in advance.
    Junior Member Two Rings Sla's Avatar
    Nov 22 2023
    odessa ukraine
    G 052 145 S2 front diff oil 1L
    G 055145A2 102686=105778=110070 transfer case oil 1L (I uploaded motul original very expensive)
    G 052 145 G 055190A2 rear diff 1L
    G 060162A2 S671090312 automatic transmission oil 1L
    1087.298.368 HX189KIT automatic transmission filter
    G05 551 5A2 rear diff 1L
    There are two types of oil in the rear diff (two sections)
    but it's better to check by VIN
    Established Member Two Rings joeyjazesmith's Avatar
    Mar 11 2021
    boogy down, NY
    has process for transmission and rear diff.
    C7 2015 Audi S6 | APR Stage 1 ECU tune | APR TCU tune | ECS Performance Engine Mounts | | ECS Luft-Technik intake system | ECS Billet Aluminum Underbody subframe brace | 034 Motorsports street density control arms | 034 Motorsport adjustable swaybar links | JHM Oil Strainer relocation Kit | TGK Motorsport Coolant Tank AN lines | Leyo Shift Knob | Uniden R7
