I've been doing some research on my no heat issue. I've replaced the outside air temp sensor, the coolant temp sensor (the green one near the fire wall), the sensor near the cabin air filter, new t-stat when I did the t-belt job one year ago, flushed out the heater core. I came across this video where you can fix you blend door flap by using these plugs. Has anyone used these plugs?
