Hey y'all, listing a 2001.5 tiptronic santorin avant with 149k. The car has zero rust from top to bottom after residing in OR most of its life. Turbos are very healthy with about 10k miles. See photos for quality.
Within the last 1,000 miles, I’ve replaced the following:
-OEM timing belt package, water pump, thermostat, and all associated pulleys, idlers, and tensioner and GENUINE tensioner bolt
-Newer BW K03 turbos
-Serviced the trans with new fluid and filter (trans has 120k miles)
-Valve cover gaskets, cam seals, half moon seals, cam chain tensioner gaskets, and cam plugs
-Resealed lower oil pan
-Replaced green check valves
-APR snub mount
-Headliner
-Rear main seal
-LCD cluster w/OEM LCD and polished facia by Litke
-Center mirror (with compass)
-Cupholder
-Cabin filter
-Engine filter
-Spark plugs
-Toyo Extensa HD (245/45/17) tires
-Driver and passenger side mirrors
Small mod list includes:
-SSAC Twin II exhaust
-Piggie downpipes
-Samco silicone hoses
-Drilled/slotted front rotors
-APR Stage 1 tune
-Bilstein shocks (also new within the last 1,000 miles)
There are three items that are worth noting. When I bought the car, it had a blown passenger turbo, and was hit in a parking lot. I pulled the engine and replaced both turbos with newer K03s. There is still a fair amount of smoke coming from the passenger side exhaust from oil residue depositing in the exhaust/DP. This will take some time to burn off. I have borescope photos of the newly installed turbos that show evidence that they are fine and not causing the smoke. The accident was a parking lot hit-and-run that affected the bumper and PS fender, but there was no damage to the frame rail. The wreck was never reported and won’t be on the Carfax. I sourced a Santorin bumper and fender and had those painted professionally painted here locally in Denver. I did paint correction on the entire car and the paint looks amazing, with that deep metallic shine. Lastly, the heater core is bypassed.
VIN - WAUXD68D31A110661
Pics can be viewed here - https://drive.google.com/drive/folde...usp=drive_link
I’m in line with BringATrailer to auction this, but wanted to give the buyer a chance to avoid paying an additional 5%. Feel free to reach out for any questions, happy to answer.
Asking $7,500
Car is located in Denver with a clean title. Thanks for looking, PM to connect.
