I recently traded in my 2021 Audi RS7 for a CPO 2021 Audi S8. I live in the United States (Indiana). The user interface for both cars is pretty much identical. I am the key user, and no one else drives my car (there are no other users/drivers). If I have my climate control system on at the time I shut off my car, I always turn it off. I've done that with every vehicle I've ever owned. Whenever I use/used my climate control system in both Audis, I always have "sync" turned on. Also, I only listen to music via Spotify on my cell phone. Whenever I start the S8, after a few seconds, the climate control system turns on at 60 degrees and sync is not turned on, and it switches to the FM radio. It's so annoying. I cannot figure out why this keeps happening, since I always turn the climate control system off every time I shut off the car and I never listen to the FM radio.
I've done a ton of research online, I've called Audi customer service multiple times, I've read the owner's manual, etc. Nothing has helped. My research has led to confusing information. First, I've watched official online videos from Audi showing how to set up a "user profile" such that the car remembers your personalized settings, but my S8 definitely does not have that menu/option (i.e. only certain Audi vehicles have this feature). Second, I've scoured my Audi cell phone app and there's nothing in it allowing me to set personalized preferences. Third, the user information screen in my MMI says that settings are linked to the key (I'm assuming that means key fob). I've tried both key fobs, and the climate control system and radio comes on identically regardless of which key fob is used. My theory, which may not be correct, is that somehow the car has memorized a "profile" that I never set.
I've deleted myself as the key user and then re-added myself, I've done a "soft" reset of the MMI by holding down the volume knob, I've done a full factory reset through the MMI, I've removed my car from my Audi cell phone app and re-added it, and I've deleted the Audi cell phone app and reinstalled it. Nothing has helped. Does anyone have any information? From the other forum posts I've read, this is a maddening, somewhat common problem and there's seemingly no clear answer provided by Audi and there's plenty of confusion regarding the possible interplay with the MMI/Audi app/key fob/user profile/driver's memory setting on the driver's door. Thank you in advance.
