Click here for pictures if they don't show below: https://www.vwvortex.com/threads/cus...post-116411243
All prices plus shipping.
Custom made coolant stealth 'Under the intake manifold' pipe set up. Easily remove your intake manifold with out ever losing your coolant, our cars have a dumb flaw, why do we have to lose coolant everytime we change a belt, change to a bigger amp alternator, mess we the oil housing, we have to lose coolant? This also cleans up the top side of the motor. Works 100% with oem reservoir/cars.
Also included is a custom aluminum bulit coolant reservoir tank. Mount where you have room or like, can be tucked away under manifold, or battery tray, or where you have room.
$260 + shipping
As you can see from the photo there's not much too see as kinda hidden away.
New Unorthodox Billet Pulley $85
440cc Bosch green injectors $130
Billet horn/trumpet DV w/hose $65
New DV kit with springs $65
FMIC water/methanol/windshield fluid interspray bars
3 varieties left $140 each
700HP 255lph high performance pump kit with Hella high performance relay, fuel baskets, rings, fuel level, etc. The relay fits nicely above the tank/be inserted under your metal access plate. $120
