Results 1 to 4 of 4
    Junior Member Two Rings Bed's Avatar
    Aug 08 2023
    LA
    Part number for SAI hose?
    A while back i noticed my secondary air injection hose was snapped right in half, one of the main plastic ones the that connects to the pump and more specifically the one that connect to the pump (to my knowledge), then connects to another hose that then runs under the super charger. I was looking on ECS Tuning and they have 3 different hoses on there, but 2 of them i cant decide which one is the one i actually need. Does anyone know what this part number is by chance? I have attached a picture diagram with the hose i need circled.
    edit: i forgot to link the ECS tuning post aswell, here are the 3 hoses i have found on there, just not 100% sure which one is the correct one: https://www.ecstuning.com/Audi-B8_S4...Air_Pump/Hose/
    Jul 16 2018
    Atlanta
    You have to be specifically accurate about which engine you're talking about when it comes to these kinds of things. Is it a B8.0 CCBA, or a B8.5 CGXC / CTUB?
    B8.0 - 8T0133817D is the feed from air box to pump; 06E133817J is the output from the pump; 06E131143AK is the T to the valves
    B8.5 - 8T0133817F is the feed from air box to pump; 06E133817AB is the output from the pump; 06E131143AJ is the T to the valves
    Aug 08 2023
    LA
    It is the B8.5 2014 specifically, i forgot to mention that sorry
    Aug 08 2023
    LA
    06E133817AB Would be the part number i an looking for from the sounds of it, thanks for the help above!
