After some time thinking about it, I've decided to list my RS4 converted 2001 S4 sedan for sale as I really have not had time to get the car out and enjoy it with some of the time pressures of work. The car is, in my opinion, a very nice example and I would love for it to go to someone who will appreciate it and be a good custodian for it.
The car has less than 5,000 miles since the bodywork and less than 10,000 miles since the motor build (will confirm actual miles when I get home from travel). The bodywork and paint was done by Joe Adams in MD; I shipped the shell back and forth to make sure it was done by one of the best in the business. The motor build was done by Bluewater performance in Denver, CO.
Note: This is an expensive ~25 year old Audi, I understand and expect it will not be for everyone. I am likely forgetting some items on the car but happy to discuss with serious buyers.
I am located in Sterling, VA.
Price: $57,000 OBO
The Basics
Year: 2001
Color: Brilliant Black
Miles: ~179,000 (will confirm when I am back from travel and with the car)
Transmission: 6MT
Engine
New Build ! ~171,000 miles (will confirm)
BEL Block
Rosten Rods
81.5 Mahle Powerpak Pistons
ARP rod Bolts
ARP Head Bolts
2.8 Heads
+1 mm Supertech Valves
Supertech Ti Retainers
IE Valve Seals
2.8 Camshafts
Borg Warner RS6 Turbochargers with Tial wastegates
2.0T/R8 Coilpack conversion with custom hardwired harness using aerospace splices/shrink
RS4 Bi-Pipes
Evolution Racewerks Side Mount Intercoolers with Methanol Bungs
VAST Water-Meth
THE-Tuner Intake Hoses
4 Bar MAP
New 034 Silicone Power Steering Hose
Red Powdercoated Valve Covers
New Primary 02 Sensors
Electric Fan Kit
JHM Shifter w/ Stabilizer Bushing
VAST Oil Cooler
The-Tuner Oil Pump
The-Tuner Catch Can
Paragon Performance Turbo Oil and Wastegate Lines
New Coolant Tank
New Battery
RS4 Carbon Fiber Engine Covers
Intake
034 Billet 85MM MAF Housing
034 X34 Intake
RS4 Intake Manifold
RS4 Throttle Body
RS4 Intake Y-Pipe
RS4 Bi-Pipe
Transmission/Clutch/Differential
STASIS Close Ratio Transmission ($5,500 NLA)
STASIS 4:1 Rear Differential
Ringer Racing Stage 5 with new steel flywheel (<2k Miles)
New Clutch Slave Cylinder
Rear differential seals and fluid serviced at Berg Performance <4K miles ago
Fueling
Injector Dynamics 1050x
Walbro 450 Pump hardwired via relay
GFB Fuel Pressure Regulator with Gauge
RS4 Fuel Rail
*Note: Intent is to set up for E85, should be ready to go with no issues, tune is in progress*
Exhaust
485 Designs 3" downpipes
Custom 485 Designs 400 Cell Catted Midpipes with post-cat 02 Bungs
Custom 485 Designs test pipes
Custom 3.5" 485 Designs Exhaust
Body
Car is Painted Porsche Brewster Green, including engine bay. Original color is black.
OEM RS4 Front Bumper
OEM RS4 Front Fenders
OEM RS4 Front Fender Liners (New with build, previous wheel setup wore some holes)
OEM RS4 Front/Rear Doors
OEM RS4 Sideskirts
OEM RS4 sill plates
OEM RS4 Rear Quarters
OEM Euro Rear Facelift Trunk with Shaved Lock Cylinder
OEM RS4 Rear Bumper
Reiger Rear Spoiler
*RARE* Fiber Images Carbon Fiber Hood with color matched Aerocatch Hood Pins
New Windshield Cowling
New Fuel Cap
OEM RS4 Grill
Freshly *polished* and clear powdercoated aluminum sport mirrors (RS4 Look)
Aero Wipers
Entire car is PPFed. Entire car is ceramic coated.
Lighting
OEM Valeo HID Ecodes
New Sidemarker Lights
Refreshed RS4 FogLights
Chassis
Stern Street Motor Mounts
Stern Transmission Mounts
ECS Tuning Rear Differential Mount
034 Billet Rear Differential Carrier
034 Rear Sway Bar
034 Front Subframe Solid Subframe Bushings
AWE Drivetrain Stabilizer with bushing replaced <5k miles ago
Rear Differential Seals and Fluid Replace by Berg Performance in 2020
Brakes
6 Piston 18Z Brembo Front Calipers/350mm Girodisc Rotor Front Brake Kit (2Bennett)
4 Piston 18Z Brembo Rear Calipers with wilwood parking brake, voshmods brackets, 300mm B7 slotted rotors
Brakes are powdercoated silver
Suspension
Bilstein PSS9
Note: Car is plumbed and wired with a compressor for stanceparts air cups. I have a brand new set of cups and H&R Ultralow coilovers ready to install in the car
H-Sport Swaybars (F&R) with 034 subframe reinforcement
All Control Arms replaced in 2019
Interior
Recaro A8 Seats
Wedge Engineer Seat Brackets
RS4 Steering Wheel (Alcantara)
RS4 Shift Knob
Carbon Fiber Beltline, Door Card, Shifter Surround, and Emergency Trim
New front floor mats
New B-Pillar trim
OEM RS4 MPH Cluster with Color MFD
Infinity door speakers
Infinity 5 channel amplifier
Infinity 12" subwoofer
Panasonic Head Unit with Bluetooth
Innovate ECB-1 wired with Boost, Ethanol Content, and Wideband 02 with fresh sensor
Refreshed Center Console from AZ car
AWE Pedals
Aluminum Dead Pedal
Euro knee bolster
New ceramic tint in 2022
Wheels
Rare and custom 19x10.5 Abt A10 color matched to car. These are stepped up 18->19 wheels
255/30/19 Bridgestone Potenza Sport
https://imgur.com/a/MeUBNXb
