Results 1 to 11 of 11
    Active Member Two Rings SaVAGeSoot's Avatar
    Sep 30 2024
    Kw, ON, Canada
    TDIs - Are there many of you around here?
    Hey guys.... new guy here.... drive a '14 A6 TDI (and a '14 Touareg TDI - no relation)
    I've poked around the forum a little and didn't see many TDI mentions... there's some here and there.....
    Just wondering if there's many of you oil burners around here, or if we have some dedicated areas\posts already going for us sparkless folk.
    May 20 2010
    Few of us. I have a build thread that is slow, and while i have a couple updates, I will be doing more in the next month once I'm back from a road trip I am prepping my RS for.
    A lot of TDI movement is in FB groups now.
    2016 A6 TDI Prestige - Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige / Ecru-Brown interior
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD
    2007 A4 2.0T quattro - Gone but not forgotten
    Sep 30 2024
    Kw, ON, Canada
    Yes, I'm quickly read through your thread.... I'm not a FB guy, so I haven't bothered to go there.....
    I was going to start hounding you for EGT logs and stuff on your build, but I haven't gotten to it yet.
    May 20 2010
    The highest I recall seeing my EGTs go was maybe 800 C (~1470 F). Generally I'm not even close to that and say less than ~600 C (< 1100 F). But also since doing the DPF delete, I've lost one of my EGT sensors (reads -40) so I only have one to rely on.
    Sep 30 2024
    Kw, ON, Canada
    The only EGT that I'd care about is #1 which unless you're running a really crappy tune, you should still have. (and hopefully rely on)
    I saw you talking about IATs too, so I'll have to log the OEM setup to see how bad it is.....
    What's your Lambda like with the tune?
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    I still pop in occasionally. Audi bought back my A6 TDI in 2022. Even at 147k miles it was still a torque monster.
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Sep 30 2024
    Kw, ON, Canada
    Quote Originally Posted by Kevin1 View Post
    Awesome... hope I get to keep mine that long as well....
    May 20 2010
    Quote Originally Posted by SaVAGeSoot View Post
    Haven't looked since I got the Malone some years ago. Can log again over this weekend.
    Sep 30 2024
    Kw, ON, Canada
    I did a quick log last night on my commute home on the Touareg.... had intended to do a similar one with the A6 just to compare the stock CNRB with the CPNB.... never got a chance to.
    Hopefully tonight or tomorrow I can take the A6 for a rip.
    Sep 30 2024
    Kw, ON, Canada
    Here's a short sample of what I'm seeing on my OEM setups.... not a lot of data as I did these on my commutes to and from work, in traffic.
    Touareg
    A6
    Sep 30 2024
    Kw, ON, Canada
    Well, there's something I wasn't expecting to see.... the Touareg's dual SMIC setup appears to be cooling better than the A6's FMIC.
    Even though the Touareg pull was done in warmer ambient temps, and it hits the EGT limitter and starts to de-rate, it's IAT delta is much better than the A6's.... this is totally not what I expected to see.
    The A6 has way better lambda and EGTs and its pull was in way cooler ambient temps too.
    Touareg on left, A6 on right.
