Results 1 to 4 of 4
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    are A4 and q5 3.2 calipers the same?
    they look identical and use the same 320mm rotors but not sure if they fit?
    Ivan
    Sep 29 2024
    Denver
    From what I know, the A4 and Q5 3.2 calipers do look very similar, and both use the same 320mm rotors. However, I'm not 100% sure if they are a direct fit without modifications, as there could be slight differences in mounting points or other dimensions
    Aug 19 2013
    Miami
    Quote Originally Posted by Jameshtlen View Post
    They did fit 100%
    Sent from my SM-G996U1 using Audizine Forum mobile app
    Ivan
    Jul 16 2018
    Atlanta
    B8.0 Q5 used the same TRW floating calipers as B8 A4 and A5. Even the wheel bearing housing is the same. B8.5 Q5 is what switched to the Brembo fixed calipers. Which is why they are direct swaps to B8 A4 and A5.
    2009 A4 Avant 2.0T quattro Prestige, 267k miles
