Results 1 to 4 of 4
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Auto dimming/heated mirrors from 2016 S6
    Sold the car and no longer need these. Looking for $100 shipped.
    Active Member Two Rings SaVAGeSoot's Avatar
    Sep 30 2024
    Kw, ON, Canada
    I may be interested if you're willing to ship across the border.... just need to confirm part fits my '14, and that my mirror heater has failed since I just noticed the driver's side isn't clearing up dew the way it should.
    Fry Sauce, UT
    Quote Originally Posted by SaVAGeSoot View Post
    I've got no problem shipping across the border. I just checked and part numbers match between 2014 and 2016 so you're good there
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Sep 30 2024
    Kw, ON, Canada
    Quote Originally Posted by agentsmith988 View Post
    Thanks, I have also confirmed the PNs.
    I have to do a little more digging first as I'm also having an intermittent signal repeater issue in that same mirror... so now I'm suspecting the shared ground to be the issue... probably a flaky connection.
    L131 - Driver side turn signal repeater bulb
    Z4 - Heated exterior mirror on driver side
