Results 1 to 6 of 6
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    Looking to buy a 2017 S6. Is there a buyer's guide of things to know or look for?
    FIgured there would be a sticky, but don't see anything listed. Any guidance would be appreciated.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Junior Member One Ring
    Jul 26 2020
    New York
    #1 did a dealer perform the turbo oil screen recall. Its fairly extensive and you should not get a car that has not been "fixed"
    #2 maintence is expensive. I am sure others have better prices but you are looking at hundreds for oil changes and thousands to replace brakes and rotors
    #3 my 2017 S6 is my most expensive and most favorite toy. After almost 5 years with it, It brings smiles every time i drive.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by Silence View Post
    May not be a sticky, but plenty of similar questions asked over the years if you search for it.
    Control Arms - inspect the bushings. $1500-$2k repair
    Motor Mounts - can be tested with VCDS. $800-$1500 repair
    Oil screen recall - Obvious one. Has it been performed already? $$$$
    PCV/Oil Separator (oil consumption) - has it been replaced before? Many cars have aged out, or will soon, from the Extended Warranty. Cannot really inspect, other than if you hear a loud whistle, or potential suction on oil cap when removing. $$$
    Depending on mileage, will need brake fluid flush, Sport Diff (if it has it) flush, spark plugs, and other wear items.
    Maintenance records are best for these, and setting aside funds for regular/emergent needs
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Established Member Two Rings Blackcoog's Avatar
    Sep 29 2009
    Minneapolis, MN
    If it is over 70K, as noted above, you are very likely to need new engine mounts and new control arms. Mounts should throw a code if they are bad enough, not always though, so you can scan the car with VCDS. Another way to check them is to run the vibration test through VCDS so you can verify each mount can still vibrate. They vibrate loudly during that test. I changed my the mounts and control arms this year and it was a huge pain. I have done a lot of car work and this was not a fun job. I installed solid filled mounts and control arms from 034. Don't buy the cheap ebay/amazon mounts, I tried them, they do not vibrate and will not communicate. Shop rates for mounts and control arms is going to be a lot of money, maybe $5k+.
    2015 Audi S6 Prestige, Audi Exclusive Riviera Blue, B&O, Black Optics, Sport LSD, DS1 Stage 2 ECU tune, RS7 inlet pipes, 034 Engine mounts, 034 control arms, Custom Intake, Custom Exhaust, PUR 4OUR Forged Wheels, RS6 Front Grille, and CF rear lip spoiler.
    2015 Audi S5 Cabriolet Prestige
    2020 Audi SQ5 Premium Plus, Magma Red Leather, S Sport Pack, Black Optics,
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Motor mounts can be shot and not throw a code. Mine were gone... no code. It failed the visual, and when I swapped em... well they were completely blown out.
    Oil screen is a safety recall, easily checked.
    Another thing folks are looking over is the air suspension, and that can be a bear too.
    Lots of the stuff listed is DIY if you're handy, and can save you thousands on labor. I don't know your skill or willingness to turn your own wrenches. That's a skill that pays dividends, especially on these cars.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by Burkeomatic View Post
    If they are shot and you run the test in VCDS it's very obvious, code or no code.
    18 S6
