Hello,
After less than a year after I solved the dynamic lighting issue on the driver side headlight, it suddenly went off completely. Took it to a reputable local shop, run all the test, switched the ballast between the left and right side. Finally figured out the problem on the driver side is the connector (see attached). The standard fix is to buy a new $1300 light. Is there a way just to get a connector with pigtail? Thanks.
