    Oct 14 2006
    by the lakeshore, mi
    I'm going to be doing a front end refresh and wondering is there anything else
    that I need? I bought the Solowerks coilovers, front control arm kit and front strut mounts. Is there front strut bearings? What about rear strut mounts?
    Current: 01 A4QM avant daily driver.
    Past: 92 ABZ 100CSQM avant, 97 A6Q avant, 93 S4, 95.5 avant, 93 S4, 91 10vt CQ, 98.5 SC'd & IC'd A4QM sedan.
    Veteran Member Three Rings QuattroBucc's Avatar
    Mar 06 2020
    B5A4 1.8TQ g25-660, MK4 GLI K04
    Santa cruz, CA
    You could do sway bar bushings also
    Oct 14 2006
    Thanks for the suggestion. I will definitely do those.
    I did a little bit more research, there isn't strut bearings for the B5 chassis.
    Jun 30 2008
    Erie, Pennsylvania
    Looks like you're in Michigan, so I'll mention it:
    If you are changing all the control arms, you might consider replacing the pinch bolt on the upper arms with a stainless version. It's a standard length that is available at bolt stores for a few dollars a piece. This avoids it rusting and locking in place, as they like to do in areas where road salt is used.
    Oct 14 2006
    Yeah that's one thing I hate about living here in MI is the road salt we use during the winter which rusts out vehicles here faster then car manufacturers car make them lol!
    I plan on using anti-seize on all the bolts that came in the control arm kit. I also plan on using anti-seize for my coilovers.
