Dear Audi Fans,
I have a 2005 A6, 4.2L, Quattro, with ~117K miles
Several weeks ago, I noticed that my passenger floor was damp after a light rain... I pulled the carpet back and it was also damp underneath, yet no standing water. I let it dry for a week. I did some water testing and found water coming through a rubber sidewall plug near the front, right sunroof (bottom) drain. I went on to check the cowl (pendulum?) drain and one was nearly full of junk.
Several days later the ESP, Traction and Brake Malfunction lights all came on, as did my air bag light yet is has since remained off. This looks like a mess to me and may be beyond my ability, yet I will try. Could this just be a coincidence?
Anyone with experience with this issue or interpreting the scan below, I will be very grateful. Thank you.
Wednesday,04,September,2024,12:26:19:48210
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 24.7.0.0 (x64)
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WAUDL74F65N037903 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 67 72 76 77
VIN: WAUDL74F65N037903 Mileage: 188300km-117004miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 560 A HW: 4F0 907 559
Component: 4.2L V8/5V G 0010
Revision: -------- Serial number:
Coding: 0007772
Shop #: WSC 09550 758 80885
VCID: 204FD9DCF37FB196E3-8074
VINID: 9D19547071161857800C72400CBF5A91AB
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 G HW: 09L 927 156
Component: AG6 09L 4.2L5V USA 0070
Revision: --H01--- Serial number: 0044539
Coding: 0001002
Shop #: WSC 02327 785 00200
VCID: 285FC1FC9B4F49D6AB-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 E HW: 4F0 614 517 A
Component: ESP8 quattro H03 0010
Revision: 00000000 Serial number: 00000000000000
Coding: 0004456
VCID: 2643CFC4915B5FA699-8072
1 Fault Found:
00493 - ESP-Sensor Unit (G419)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 188306 km
Time Indication: 0
Date: 2024.09.04
Time: 12:21:38
Freeze Frame:
Hex Value: 0x0280
Hex Value: 0x4082
Hex Value: 0x0000
Hex Value: 0x0091
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: None
VCID: 55A1B808BCBD043EC0-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360GI047502264
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 31692C98A895081E7C-8064
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000040920
Subsystem 3 - Serial number: 0111.08.040000000100010226˙
Subsystem 4 - Serial number: 010226˙
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000023 Serial number: 00000000046229
Coding: 0000040
VCID: 5BB5AE309A99D24EF6-800E
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AE HW: 4F0 907 279 A
Component: ILM Fahrer H32 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0102023
Shop #: WSC 00000 000 00000
VCID: 6CD7FDEC4F37A5F60F-8038
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 00000
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD4026098
VCID: 1C37ED2CDF1795763F-8048
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7G0219562
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 72
Mileage: 188306 km
Time Indication: 0
Date: 2024.09.04
Time: 12:05:13
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 46 AIRBAG AUDI8RH28 0310
Revision: 09H28000 Serial number: 00359D070B6B
Coding: 0013366
Shop #: WSC 22163 444 58758
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME037648593
Subsystem 3 - Serial number: 6342CSME03127952Y
Subsystem 4 - Serial number: 6351HSME03664F045
Subsystem 5 - Serial number: 6361HSME03594F6FP
Subsystem 6 - Serial number: 6371VSME031C00649
Subsystem 7 - Serial number: 6381VSME031C4809L
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 B
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90022042160019
Coding: 0012241
Shop #: WSC 02323 785 00200
VCID: 66C38FC451DB9FA659-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4F0-920-KOM-V1.clb
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H08 0460
Revision: 00200000 Serial number: 4I250A384
Coding: 0065203
Shop #: WSC 45478 001 104857
VCID: 1E33E724C90B8766D1-804A
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 080080472602E0
Coding: ECFE73CC1B7904
Shop #: WSC 23011 444 84441
VCID: 275DC2C0965146AEA2-8072
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 61C99CD8B8F5F89EAC-8034
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378B-057517919
Shop #: WSC 23011 444 57521
VCID: 387F11BC4BEFD9563B-806C
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: a•#
Coding: 0035691
VCID: 2959C4F8804570DEB4-807C
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000543210000
Coding: 0423997
VCID: 2C573DEC8FB765F64F-8078
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 72
Mileage: 180055 km
Time Indication: 0
Date: 2019.08.12
Time: 08:51:35
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 14S00001 Serial number: 01907040022165
Coding: 0000016
VCID: 224BD3D4FD73A386F5-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000024766
Coding: 0011114
VCID: 5EB3A724898BC76691-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: ‚™#
Coding: 0035691
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0006022
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352HS047550764
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0400
Revision: 00000000 Serial number: 00000000040420
Shop #: WSC 26153 444 00583
VCID: 2345D6D0E269AA8EFE-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1408090073
Coding: 344630393135313035442056413031343038303930303733
Shop #: WSC 00000 640 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0035370
VCID: 69D984F840C5B0DE74-803C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000407260196
Shop #: WSC 12336 024 394758
VCID: 3467258C57873D3617-8060
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0035370
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0020
Revision: --.--.-- Serial number: 11730420500316
Coding: 0001206
Shop #: WSC 131071 1023 2097151
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007500532
Coding: 0010900
End-------------------------(Elapsed Time: 06:25)--------------------------
