Results 1 to 2 of 2
    Junior Member Two Rings
    Apr 20 2022
    Montreal
    P0492 error code and SAI cleaning
    So this code just triggered a CEL after a cold start (it was stored permanent in the ecm prior), after doing research it seems to be mostly related to the clogged SAIs when both banks trigger it. Could there be a other cause when it's 1 bank only? I am getting under the supercharger to replace the pcv and leaky valve gasket this week, should I be looking for anything specific related to the SAI?
    2018 Audi S4 Sold
    Current Daily: 2017 SQ5, 2009 Audi A4 Avant
    Current Weekend: 2019 Audi RS3
    Veteran Member Three Rings Discipulus's Avatar
    Sep 20 2016
    Portland, OR
    The SAI if I remember correctly is located right behind the left and right upper timing covers at the back of the engine. To access them you'll need to remove the catalytic converters and heat shield. Then you can remove the SAI, or sometimes called a combi valve?? and inspect the ports to see how clogged they are. I've never had to clean these myself, but I have removed and reinstalled mine when replacing the upper timing chain tensioners.
    APR Stage 2 DP | JHM 207mm Crank | JHM HX | EPL TCU | JHM Race Pipes | JHM High-Flow Cats | Euro-Spec SQ5 Springs | Koni Shocks | 034 Motor Mounts | ECS Drivetrain Inserts | ECS Aluminum Cross Brace | AFE Pro Dry air filter | 034 Silicone Intake Tube | 034 RSB | TRW metal endlinks | ECS Stainless Brake Lines | RSNAV S3
    2015 Q5 3.0T - Current
    2011 A4 6MT - Sold
