Updated price $4,500 CASH
One small dent on the passenger front fender, I was backing out of the drive way and brushed it against a tire that was sticking out of my other parked car. Driveway is on a hill, so the front wheel was fully turned on the other car, causing the tire to stick out. This was the first night I brought it home and I wasn't used to the auto-dimming side view mirrors, I didn't see it.
It has an oil leak, that is annoying, but not worth fixing IMHO, it isn't losing that much oil. I also have a second passenger seat, it was the original. As listed below, we replaced the motor, it would work out of the car, but not in the car, so we found a used one that is mint. Both passenger seats are mint. The drivers seat has minor wear as normal from getting in and out hear the shoulder area.
2 Check Engine codes related to emissions since the heater hose was replaced. Hasn't been driven much the last 2 years, it's due for a transmission fluid change. Everything else isAudi Engine Code_20240615.jpg great.
It also comes with the "wind buffer" for when the top is down and I have the bag for it.
Audi PS side full.jpgAudi PS Side and rear corner.jpgAudi PS side front corner.jpgAudi Dr side and front.jpgAudi Dash.jpgAudi PS Seat.jpgAudi Dr seat close.jpgAudi Rear seat and wind buffer.jpgAudi Trunk.jpg
The following Repairs have been done since I purchased it in December 2017:
Most recent to oldest repairs:
Heater Hose
Oil Cooler and Hoses + O Rings
Radiator Fluid Changed
Lube Job - Chassis
Full Synthetic Oil change
New Battery
Air Pump, Relay and Fuse
Air Bag sensors Pair
2 New tires (due to flat, had to replace in pair, had low mileage though)
Radiator, coolant, upper radiator hose
Oil Cooler Seals
Alternator + Belt
Valve Cover Gasket and Spark Plugs
Thermostat
Coolant
Tensioner and Idler Pulley
Oil Change
Tire Rotation
4 Wheel Alignment
Tire Rotation
Crank Position Sensor
4 Wheel Alignment
Power Steering Rack
New/Used Passenger Seat
Passenger Seat Recline Motor (original seat)
Axle Kit inner Boot Driver Side
Brake Fluid Flushed
Brakes - Front Pads + Rotors
Brakes - Rear Pads + Rotors
Labor Brakes, CV Boot
New Tires
Cabin Air Filter
Restore Headlights
Oil Change
Drive Shaft + CSB Bearing
Power Steering High Pressure Hose
4 Wheel Alignment
Balance Front Wheels
Rearward Lower Ball Joints
CV Joints
Tires Balanced
Catalytic Converters
Heater Hose
Located in Dayton Ohio.
Currently has a Kenwood stereo, I will be replacing the stock Radio and keeping the Kenwood.
