Results 1 to 3 of 3
    Junior Member One Ring
    Oct 08 2010
    Richmond, VA
    Adaptive suspension tests?
    I have a 2013 3.0T Q5 Sline with OE adaptive suspension struts and H&R lowering springs and I can't understand if one of the struts has failed. I don't have any codes in VCDS or warning lights on the dash. The adaptive settings seem to change ok and there is no fluid leaking from the struts but the ride just seems kinda bouncy even on the Dynamic setting. I replaced all of the front control arms about 3 months ago and they all look to be in good condition with no loose fasteners.
    Is there a specific way to test these struts with VCDS or a multimeter or just a simple manual way?
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    The suspension is compressed 1.5" or however much hr lowering springs go, therefore it is naturally bouncy. I ran that setup for a bit and couldn't stand it so switched to kw coils a few years ago and haven't looked back.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Oct 08 2010
    Richmond, VA
    Thanks Dave, that makes a lot of sense if the new front control arms have tightened everything up and now the bounce is more prevalent.
    I find it surprising there is very little info on this type of strut regarding testing or fault finding.
