Results 1 to 18 of 18
    Apr 26 2014
    San Diego, CA
    Adamazing's Build Thread - B9 SQ5
    Been meaning to start a build thread for a while. Finally got around to taking some pics this weekend.
    2018 Navarra Blue SQ5 Premium Plus
    Performance
    APR Stage 1 (E85)
    IE Air Intake System
    IE Turbo Inlet Pipe
    Wheels
    Avant Garde M520r
    21x10.5 +33mm Front / +30mm Rear
    Polished Liquid Bronze with Brushed Faces and Barrels
    Suspension
    CETE Active Air Suspension Lowering Module
    034 Motorsports Dynamic+ Braking Package
    Michelin Pilot Sport 4S (295 / 35 / 21)
    Exterior
    Satin Vinyl Trim and Badge Blackout
    RS Style Quattro Grill with Fog Surrounds
    Misc
    Llumar Formula One Ceramic - Pinnacle Series (15% Front, 40% Rear)
    deAuto LED Reverse Bulbs
    Exhaust Valve Delete Sim Module
    Current State
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Sep 28 2010
    NW NC / DE
    Looks killer my man! 👏🏼
    Apr 26 2014
    San Diego, CA
    Thanks Mops, and thank you for the the advice and guidance on fitment combinations! Came out even better than expected.
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Looks great. How is the clicking of the 034 brake rotors?
    2021 SQ5
    2008 A4 Avant 6 speed
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by ballinb5 View Post
    It's loud all the time, but you only hear it when driving with the windows down. The sound bounces back off whatever you're passing by. Really notable when you're driving next to a center median or divide, but it's always there regardless. I'm still trying to get used to it.
    It's a good kit though. A little over 22lbs of unsprung weight reduction compared to stock, with added benefit of SS lines which definitely provide a notable improvement in brake feel and engagement.
    Jan 30 2024
    Tampa, FL
    Quote Originally Posted by adamazing View Post
    So what is a better 2piece rotor without clicking noises? Just curious for when I’m ready to change!
    Apr 26 2014
    San Diego, CA
    To be clear, I'm not suggesting it's a bad product or that there's a better rotor out there. It's a great kit. But as all with j-hook rotors you get notable rotor noise as a result, and that noise will be subjective to each person's ear whether they hate it, don't mind it, or love it. I'm bordering between the first two and slowly moving to the middle.
    ECS, JHM, and Girodisc are among others that make two-piece rotors for our platform. While Stoptech, Revo, and some others offer them as part of a BBK kit.
    Jan 16 2011
    CA
    Thanks for the reviews. I really want the 034 rotors but don't think I can deal with the noise for a family car. You mentioned the ss lines, is there any downside? If I don't install those, will I still get a nice feel? Thinking of doing 2piece front rotors, normal rear, akebono pads, and brake flush
    2021 SQ5
    Apr 26 2014
    San Diego, CA
    That approach would be fine, since most of the inertia bias is on the front brakes anyway. Doing the rear would help remove some unsprung weight. No downside to SS lines - they'll help provid you with a firmer pedal feel because there's less flex compared ot the OE lines. You'll use less pedal force and will help generate a more linear engagement.
    I've had slotted two-piece rotors before (Stoptech BBK) and they were quiet from an NVH perspective. I'm personally not a fan of cross drilled rotors.
    Jan 16 2011
    CA
    Thanks! Have you heard of anything about the JHM 2-piece rotors? They say they save over 10lbs and look like 2mm thinner than stock -- is that safe? At what point would that become a problem? https://jhmotorsports.com/front-roto...s4-s5-sq5.html
    Sorry to make this a brake thread haha
    2021 SQ5
    Apr 26 2014
    San Diego, CA
    No worries at all. Unfortunately, I dont have any first hand experience with them so I can't say for certain.
    Apr 26 2014
    San Diego, CA
    Finally had the time and resources to install the 034 Motorsports Transmission Mount Insert. Had this laying around for a while, but a lot of my tools, including my jack, were stolen a few months back. Picked up a new jack and triple square sockets this weekend so this finally went in. This was one of the earliest mods I did to my B8.5 A4 and it made such a subtle but great driving enhancement. Really cuts down on the shock shift in lower gears.
    Sent from my Pixel 9 Pro XL using Audizine Forum mobile app
    Dec 05 2006
    So. Cal.
    Great, How is the NVH on that piece? I've ordered one but the one from ECS with the poly in it also . I heard that the 034 introduces a wee bit of unwanted NVH into the cabin.
    Established Member Two Rings cmil527's Avatar
    Oct 16 2023
    Old Bridge NJ
    Looks great!
    2024-SQ5-Glacier White/Magna Red-Prem+-Options:S Sport,Nav,Sport Exhaust,BO Pkg & 21'' BO Wheels,Nappa Leather,Audi "S" Beam,Cargo Cover,Black Rings,Audi Guard-Mods:HRE FF10-21X9.5''-Tarmac-255/40 Pirelli P-Zero,20% Side & 35% Windshield Tint,JB4 Map 6 w/Bluetooth,Roar Pedal,034 Turbo Inlet & Trans Mount,AWE IC,Roc Euro Intake,ECS X-Pipe/Res Delete,Badgeskins DRL Kit,TGK Lowering Links,DSG Red CF Paddles+PSB,Maxton Kit w/V2 Lip & Roof Spoiler
    Apr 26 2014
    San Diego, CA
    No NVH at all that I've noticed, same as my B8 A4. The factory rubber/cushion is still in place and it does a good job of dampening vibration by itself. This just firms up the shifts to reduce the feeling shift shock you occasionally get in the cabin. Borderline alomost feels like a CVT at times (but in a good way - just continuous pull). I would expect the ECS version to be virtually identical, even with the polyurethane design.
    Quote Originally Posted by cmil527 View Post
    Looks great!
    May 04 2011
    Southern California
    What’s the led reverse bulbs do that’s different than stock?
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by waylonrobert View Post
    Just significantly brighter, and whiter. The rearward illumination through the reverse camera is much brighter than before.
    Dec 14 2023
    Tulsa, Oklahoma
    Very nice!!!
