Yeah, OBDeleven, such a pain. So the "fault code" of 01134 is not an error code, it's a "DFCC", which is a component identifier. This would be different if it was an OBD-II code like Pxxxx. So 01134 just means "the alarm unit". The actual numerical error code is not given, but the text interpretation is: "no signal/communication". Ok, so now we have a more complete error state. The J393 BCM2 states "no signal/communication" with the alarm horn unit. We also note it says no communication with the humidity sensor as well.
The fuel filler door lock actuator code is a common known issue. The locking actuator (open the fuel filler door, see the post that pops out, push it in, notice it rotates and locks in, then if you lock the car and push on it, it doesn't release (as it should since it's locked), that's the actuator) starts to flake out until it stops unlocking when you unlock the car and you have to use the red pull cord above the J393 to get the fuel filler door to release. It's like $50 and an easy replace.
Back to the no comms. The J393 to H12 alarm horn connection is a single wire LIN bus system. Black 32-pin, pin 16 (violet/white) goes out to the H12. At the H12 is a 3-pin plug. LIN on 1, ground on 2, 12v on 3. This 12v is term 30, always on. So you should measure 12v from pin 3 to pin 2, otherwise the H12 is "unpowered" and the comms error is just a result, not a cause. That 12v does come from a fuse, fuse 12 in column red on the driver's end of the dash.
The other no comms, to the G355 humidity sensor. This is a different pin on that black 32-pin, pin 32 (violet/yellow). So separate LIN bus than the H12 one. The G355 is housed in the rearview mirror mount, and it's pins are on the 8-pin connector plug: 12v on 1, ground on 2, LIN on 7. The 12v there is also always on, but from fuse 1 in column brown on the driver's end of the dash.
Is it a power issue, or a LIN wire issue? Another thread where it turned out the wire from the J393 to the H12 had failed.
https://www.audizine.com/forum/showt...n-Not-Sounding
