Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
  1. #41
    Junior Member One Ring
    Dec 15 2024
    Surrey, UK
    Quote Originally Posted by chasiu View Post
    I just put in a Recaro Pole Position on the driver's side and plan to put a Recaro Sportster CS (heated) for the passenger side. Has anyone had a Parking brake malfunction come up after removing OEM seats? Also did anyone need to transfer the rail position sensor over to their aftermarket seat for the two-stage aribags?
    how's the seat height in comparison to th OE seats
  2. #42
    Senior Member Two Rings chasiu's Avatar
    Jul 31 2014
    Toronto, Ontario, Canada
    Quote Originally Posted by TTRRRRRRR View Post
    Unfortunately, I do sit a little higher than OEM and I would prefer to sit slightly lower. However, I did re-use a Bride floor mount with sliders that came off a RS3 so I was thinking that was why I sat a little higher but I did see the thread about aftermarket seat height being an issue even with floor mounts designed for the TT 8S.
  3. #43
    Dec 15 2024
    Surrey, UK
    Really?
    I'm surprised, I would have thought aftermarket seats would sit a lot lower compared to OE seats.
  4. #44
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Got a little distracted with a cross country move; not to mention the car has been at the shop since March to fix a few things. Found out the source of my false knock was from 3 cracked pistons and a loose flywheel. Either way, I’m about to wrap this project up soon. I’m still getting a code for the passenger seat because I believe I damaged the pad when I removed it. The good news is, SC Skunkwerks will have a cheap solution very soon and I’ll be picking that up. Last step of this project will be installing the new harnesses I just picked up.
