Results 1 to 3 of 3
    May 20 2022
    New Jersey
    Issue with locks and mirror
    Hi everyone. Wondering if someone might be able to point me in the right direction repairing these codes I'm getting on my 2012 A6. I will say the mirror doesn't fold on this door and the keyless entry doesn't work on the entire car. I have checked out the wiring from the car the door and it looked good.
    May 20 2022
    New Jersey
    Any help would be appreciated.
    Established Member Three Rings Avantly's Avatar
    Oct 02 2023
    Squirrels, Chickens, and then there's the mice :/
    "Pure Michigan"
    Quite often a "short to plus" actually means "open circuit" as the diagnostic circuit is pulling the wire to (+) to see if it rises when it shouldn't.
    These cars are 12 years old now and the doors have been opened and closed many times. One thing to check would be the wires in the boot between the door and the frame, usually they break near where they enter the door. Haven't seen this on any C7's yet but who knows.
    Since all of your codes are for the Driver's door, I would first be determining what ground the driver's door module uses. It is probably near the drivers door pillar. If the ground for the door was definitely good, and the wires in the boot looked good, I'd be pulling the door panel to look at the door module... Maybe it has gotten wet and is corroded? If this is the case it should be obvious.
