Results 1 to 4 of 4
    Oct 31 2023
    Northern California
    What is this module?
    It lies behind the pocket on the passenger side of the trunk (hidden behind plastic in this picture) and has three cables (circled) going into it. The grey connector came disconnected in my new to me 14 B8.5. When I try to turn off the soundaktor via VCDS or do an auto scan, the A9 (structure borne something) module is unreachable and I'm wondering if that could be the cause.
    Also, is the coiled cable OEM? I'm guessing not, but I can't see where it comes from or goes to. The car came with an aftermarket sub, but it is connected to the stock wiring.
    14 Ibis White S4 DSG
    Jan 04 2021
    BMW x3 28i/ CBR F4i/ YZ125
    CALI
    i thought it was backup camera or dvd module cant recall tbh. I dont have that cable in my b8 so I dont think its oem
    Established Member Two Rings billspudman's Avatar
    Jul 15 2013
    B8.5 S5, B8 S4, C5 A6 avant
    Plymouth, MA
    Its the rear camera module, looks like there was a problem with the grey fakra cable and someone re-wired it. Normally there is a grey and green connection there. The coil of cable is the replacement cable. I assume the rear camera works?
    Oct 31 2023
    Northern California
    The camera does work so that makes sense. Thanks!
    Edit: I did a little more digging to see where the coiled cable goes to and from and it goes from the top fakra connector on the module into the cover on the hinge of the trunk, so it looks like it is a replacement cable for the backup camera. Still curious what the third connector at the bottom of the module is that doesn't have anything plugged into it though. I assume the unplugged cable must be the original defective backup camera cable.
