Results 1 to 6 of 6
    Feb 09 2008
    ct
    Installing aftermarket radio need some help
    installing aftermarket radio accidentally blew the radio fuse trying to connect the remote turn on for the amp. Replaced fuse getting no power to the radio. i am getting no power to the metra connection. Is there another fuse that i should be looking for? thanks
    Feb 09 2008
    ct
    When i connect VCDS i cannot connect to the radio module. There is no power going to radio. i installed new fuse and checked fuse behind all good.
    Established Member Two Rings Phosphorust's Avatar
    Feb 03 2024
    2023 Subaru BRZ, 1993 Ford Bronco XLT, 2012 Ford Escape
    Massachusetts
    I've got a similar issue. My aftermarket radio also has no power; it won't turn on when ignition is turned on. However, my engine also doesn't start anymore for some reason. My dash works but no crank.
    Established Member Two Rings My4udi's Avatar
    Apr 19 2020
    After market radios have a fuse of their own on the back of the unit. Check to make sure that fuse isn’t blown as well.
    Feb 03 2024
    Massachusetts
    Quote Originally Posted by My4udi View Post
    Thank you for the suggestion. I've checked all related fuses and nothing works. It's now a secondary issue because my car doesn't crank anymore
    Feb 09 2008
    ct
    I found the problem. Blown fuse that I replaced but put it in the wrong spot. thanks for help
