This is my 1990 Audi 90 Quattro 2.6 stroker build. I purchased this 90q 2.3 20v with a buddy to fix and flip.... ended up just buying him out to build the car for myself.
I wanted todo a short deck 20v stroker, very little info is out there but is doable. Had to-do some block craving to clear the rods and do some piston massaging due to old vs newer valve offsets.
Parts list so far:
2.3 7A block - rod clearance die grinding needed
2.5 AAF crank
2.3 7A head and cams
2.0 CCTA rods/pistons
12.9 Main bolts
2.5 AAF oil pump
Early 7A Bag-O-Snakes header w/vband
034 Motorsport 7A injector adaptors
034 Motorsport Silicone block breather
034 Motorsport Delrin Engine mounts
034 Motorsport Density Transmission/Diff mounts
034 Motorsport Delrin rear diff mount
034 Motorsport Rear Delrin Control arm Bushing
034 Motorsport Aluminum subframe bushings
034 Motorsport Polyurethane Snub Mount
Powerflex Black Series front control arm bushings
New Febi Inner and outer tirerods
New rear control arms
Bilstein Sports Struts/Shocks
H&R Sport Springs
Stainless braided clutch line
B3 Euro Headlights w/city light as blinkers
14point7 SLC Free 2 with LSU4.9 wideband
Volvo S60 injectors
034 Reman crank dampener
Ebay RS2/S2 Aluminum Radiators
G60 Calipers
Brembo sedan front rotors 276mm
Mako Driveshaft Center bearing
Mako Driveshaft CV's
Verkline Top Mounts Front
Verkline Rear Track Rods w/ ARB
Febi top mounts Rear
New wheel bearings
New Empi Sedan 20v front/rear CV shafts
HEL Stainless Brake lines
MST MT13 15x8 et20 with Lexani LXTR-203 205/50 R15
Over the last few years I have been collecting parts and putting together the motor.
Runs off a bucket of gas
https://youtube.com/shorts/npcSPItkE...fmnwuvdCGf_Fbr
