Results 1 to 10 of 10
    Senior Member Three Rings QwertyD's Avatar
    Oct 04 2017
    United States
    New Engine Options
    2017 Audi Q5 3.0T with 120k miles. I got a misfire on Cylinder 3. I brought it to a shop, and they basially told me there was something wrong with the long block as there's 0 compression in Cylinder 3 and 90 PSI on Cylinders 1 and 2. Compression test and leak test were conducted. They said I needed a new engine, which would be somewhere in the 20k range, which obviously wouldn't be worth it. I just wanted to see what my options are. How much does a used engine cost? Is it worth it to get a new engine or to sell it as is. I'm running a dual pulley 034Motorport tune with tons of modifications. Thanks for reading. I'm stressed out trying to figure out what to do. I've had this car from new.
    Sent from my SM-N986U using Audizine Forum mobile app
    AKA: Dhoang57
    Jul 16 2018
    Atlanta
    Can't speak to the economics side of this situation.
    The engine is a CTUC, so any 3.0T from a B8.5 (MY13-MY17) Q5 3.0T or SQ5 3.0T would be a direct swap (different exhaust manifolds for the under 300hp CTUC, so you'd swap yours over if you pick up a CTUD; or leave it be since you're tuning past 300hp). You'd probably find a CTUB from a MY14-MY16 S4 or MY14-MY17 S5 to also be a direct sub (CTUB shares the CTUD exhaust manifolds, so you'd again swap yours over, or not; you might also have to swap your drive plate over if the S4/S5 had a 6MT).
    As to how did your engine nuke itself, no idea. But as soon as you said dual pulley tune, well, there's certainly no surprise anymore. I thought cyl 6 was the notorious one on these engines. Is it rebuildable, vs needing a replacement, no idea. But be sure to look through the B8 S4 and B8 S5 forums as well for similar situations.
    2009 A4 Avant 2.0T quattro Prestige, 267k miles
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by QwertyD View Post
    We are in the same boat. See my separate thread here about Engine Codes. Mine failed from piston ring land seizure of rings, but on the other bank. I'm trying to find a low mileage CTUC or CTUD used engine. Expect to pay $4000 to $6000 plus shipping depending on condition and mileage. And, then the labor. I have a shop looking for one through his sources.
    https://www.audizine.com/forum/showt...-Code-Qurstion
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Flowmaster 200 cell high flow metal core cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Oct 04 2017
    United States
    Quote Originally Posted by MSq5 View Post
    Were you able to find an engine to swap out? Are you going to do the labor yourself or through a shop?
    AKA: Dhoang57
    Feb 14 2017
    Gulfport, MS
    I am travelling now on business. I have a good shop doing the work. We have located several potential donor engines. I'll get back to the shop when I return.
    Feb 14 2017
    Gulfport, MS
    Yes, I did locate an engine in Houston at an auto salvage company. I has just been delivered. About 65k miles on it. CTUC code same as mine. I normally do my own wrenching, but this is a bit too much for me at age 74. So I'm using a respected independent shop.
    Oct 04 2017
    United States
    An update for my Q5. I took it to another shop and they diagnosed it as needing new injectors. I didn't need a new engine. They installed the new injectors and it's working as good as new now. Lol. I guess always get a second opinion.
    AKA: Dhoang57
    Feb 14 2017
    Gulfport, MS
    Glad to hear that. I just pushed it too hard too many times for too long on a dual pulley tune. 100,000 miles on a tune that aggressive may be all to reasonably expect if one has a heavy right foot.
    Feb 12 2008
    Michigan
    so what was up with the other shop saying cylinder 3 had 0 compression?
    Veteran Member Three Rings Discipulus's Avatar
    Sep 20 2016
    Portland, OR
    Quote Originally Posted by Fast4esT View Post
    Yeah agreed, how the heck did they get 0 compression on one cylinder?? They must have messed up that test.
    APR Stage 2 DP | JHM 207mm Crank | JHM HX | EPL TCU | JHM Race Pipes | JHM High-Flow Cats | Euro-Spec SQ5 Springs | Koni Shocks | 034 Motor Mounts | ECS Drivetrain Inserts | ECS Aluminum Cross Brace | AFE Pro Dry air filter | 034 Silicone Intake Tube | 034 RSB | TRW metal endlinks | ECS Stainless Brake Lines | RSNAV S3
    2015 Q5 3.0T - Current
    2011 A4 6MT - Sold
