3.0T Engine Code Question
I have a '17 Q5 with our 3.0 supercharged engine. Its 034 Stage 2+ tuned and 100,000 miles. It now has lost compression on two cylinders. Scope shows cylinder wall scoring. Likely ring land failure. Not the fault of 034, as most miles were on EPL and its my heavy right foot.
I am trying to source a low mileage donor engine to swap my pulleys and use my existing ECU. 034 says it can work that way.
This is a CTU engine code, specifically CTUC. My research says that is correct for the Q5 272 hp variant, its original OEM tune. Of course its been upgraded with all the things needed, Merc HX, 3.25 pulley ratio, RedStar shielded test pipes, downstream bottle cats, high flow intake and such.
I'm having trouble finding a CTUC code engine with low miles. I have found a low miles CTUD engine from a '16 SQ5. Given that I plan to carry over my existing ECU, will this swap work?
Is there anything different about the CTUD engine other than the ECU tune? Is there anything else I might need to know, or is this not going to work? There id sn old thread here cimparing the various CTU variants, including the "C" and "D" versions, including cimparison of part numbers of every engine part. The "C" and "D" seem to be identical except for the different ECU (272 hp vwrsus 354 hp).
Has anyone put a CTUD code 3.0 in their CTUC code Q5?
Thanks, guys
