Okay ladies and gents I'm still in the midst of this atw to awm swap and trying to get this car to start for the first time. I'm at the point where the engine swap itself is done. I however have not been able to get the dash to communicate with the ecu. Pertinent information is as follows.
  • I never performed the adaptation on the dash originally. By the time I had gotten my vagcom I was midway thru the swap and did not know how I would get the new motor to start as the final step with the old electronics
  • The dash would show a check engine light with the old harness and old ecu but not with the new harness and old ecu
  • got it to crank twice after this but never again so far, idk if that's a bad crankshaft position sensor or what, ignition also locks after a crank and you have to turn it back to off befoe trying to crank it again don't know if that's relevant or not
  • I chopped the old harness apart after discovering the new harness had been tweaked and someone had wired up the plug for the ecu relay very very wrong, simply soldered the plug from the old harness onto the new one so the relay wouldn't short, this made the bad relay code on my vcds disappear but still no cel
  • became convinced it was because of the plugs between the ecu and the cluster, soldered those from the old harness to the new and pinned the missing terminal wires into the ecu plug
  • still no cel
  • got an awm passat harness from my nearest junkyard, still no cel
  • put the project down for about a month, then traveled 3 hours to the nearest junkyard with a 2001 a4, pulled the instrument cluster, ecu, and wiring harness all from the same awm a4 and swapped those into the car thinking this would have to work
  • still no cel
which brings us to where we are now. The only ideas I have left are to go pull an atw harness and then using the passat harness as a donor and change the plugs to try and get it to start for the final step of the adaptation, or pay one of you folks much more experienced with this platform than me to figure out this puzzle. 100 usd payable however you would like to the first person to get my check engine light to come on.
