Results 1 to 8 of 8
    Junior Member One Ring
    Feb 20 2019
    Creedmoor nc
    Angry BAD VIBRATION only when applying gas.
    as the title states i recently purchased a 2007 a4 quattro that has a very bad vibration whenever trying to accelerate. The vibration is in the car not the steering wheel. if you let off the gas the vibration stops. if you push the clutch in the vibration stops. does not vibrate at idle. I have been reading towards the axles or possibly the dual mass flywheel. I am seeking any advice on finding out how to diag between the two. ive also rear about the motor mounts/ snub mount but i have checked those and seem to be fine. Thanks for any help guys
    Feb 15 2016
    Cambridge,Ontario
    did it do it when you bought it ?
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 20 2019
    Creedmoor nc
    Yes I bought it this way
    Feb 15 2016
    Cambridge,Ontario
    oh boy ... likely dumped for this reason .. this could be a good one as im sure PO tried lots before dumping car...
    dont forget the coupler underneath .. cant remember the name of it but someone will bring it up.. sound like that to me ...
    1976 Yamaha XS 360
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I would check to see if PO installed aftermarket axles, be easy to check.
    I tried a new Cardone axle ones, and its caused a tight vibration on acceleration.
    Wound up rebuilding old one.
    Sent from my LM-V600 using Audizine Forum mobile app
    Feb 20 2019
    Creedmoor nc
    nothing looks replaced that i can see. still the factory axles as well
    - - - Updated - - -
    Quote Originally Posted by Jayz691 View Post
    still the factory axles. i noticed the passenger front does have some up and down movement to it so i may try to just replace that one to start
    Feb 20 2019
    Creedmoor nc
    so update i pulled the passenger front axle out tonight and it is beyond bad. I know this will make a big difference. i noticed the passenger rear wheel also had some hop to it. getting a new axle tomorrow and will report back
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by T2ae View Post
    Buy quality.. GKN is OE
