This is the weekend for AC work. I repaired the AC in our 2010 Honda CRV, new compressor, flushed the system and got everything back together. Best it's been since we've owned it.
I do not have VCDS, so I don't know any of the live data values, but no codes are being thrown. I have taken pressure reading before, but I can't find them, so I'd be guessing at any values to post. Previous owner had made comments about the AC acting "weird". I'm guessing he had done some work, but I don't trust his abilities. I don't think the pressure measurements were all that great, but as mentioned I can't find what they had been. While I had the tools out, I evac'd the system, pulled a vacuum for a couple hours, then refilled with ~18oz of r134. The ECON light stayed on, but went off after I restarted the car.
Pressure readings are:
Low side: 50-55psi
High side: 145-155psi
Ambient temp: 90F
Based on the Honda's readings which has a similar capacity of oil and refrigerant, the high side is about 125psi low. I can hear the compressor cycle as I toggle the AC on-off, so the solenoid valve is functioning, but since I don't have the VCDS, I don't know what the high pressure is or the duty cycle.
