More Data Acquired.
I took the working Passat on a drive and watched the temps.
- While driving (ambient 70F): 83-85C average
- Could not get it to go higher, even running A/C and driving slow, everything just works too good.
- Notably, this Passat has the metal coolant flange.
- Temp Rise After Shutdown: ~9-12C
Short Drive, 55mph, 70F ambient. Data gathered Immediately after shutdown of Passat with good OEM fan:
- Temp is 85C
- After 1 minute = 90C
- After 2 minutes = 93C
- After 3 minutes = 94C
- After 4 minutes = 93C
- After a longer drive (20 minutes, 70mph, 75F ambient), I did see it the Passat spike as high as 97C. The gauge still showed dead center at this time.
I bought a Photo Tachometer to measure viscous clutch fan speed. Yay!
- Hot Passat (after heat soaking for 4 minutes shown above) showed a fan speed of 1180 RPM at idle. Good Fan!
- A4 with bad fan, at cold start shows fan speed of only 600RPM.
- That's half the speed!
Tomorrow I will gather more data points: Passat Cold and A4 Hot, before I finally change the junk fan clutch.
Update:
- Passat shows 1200 FAN RPM right at cold start idle (measured once idle drops to 800). Good Passat.
- Junk A4 Fan is still only 600 RPM or less even while actively overheating.
Junk A4 behavior:
- While cruising at 55mph, 75F ambient, coolant temp runs around 99-100C!
- Shut down at 100C, temp climbs to 105C after about 3 minutes. This is "half a tick" over the center position.
- This car will do much worse than this, depending on conditions. Stop & Go, hotter temps, etc.
- Winter totally covers up this problem. With ambient below ~50F, there is no issue shown on the gauge.
- The coolant temp reported by dash is about 2C higher than the ECU. Interesting.
Musings:
- I'm thinking my Passat might actually have a colder thermostat?
- Both of these cars have metal coolant flanges. I don't think this is a factor.
- Photo tachometer is super cool, and can diagnose this fan issue, if you know what it "should" be.
- I should gather fan rpm at higher engine speed. Maybe 3000 RPM, I will try to capture this.
