Quote Originally Posted by benznotmercedes View Post
I have the 034 mounts sitting there ready to go and was waiting for mine to go bad. Just noticed the driver side mount is leaking... the not fun one to replace. lol.
Symptoms: increased vibrations; when taking off from a light in D it almost jolts and the ecu cuts power. Doesn't do it in manual.
Not sure about this but from what I heard, if you want the sensor delete to work properly they have to be changed before the mounts fails. If you change after the mount fails they will continue to show an error with the mounts.
