I just finished a carbon clean, as well as a lot of other things. I have a few codes now present:
P10A400 regulating flap intake air, mechanical malfunction
P10A600 potentiometer regulating flap, signal too low
P10A700 adaptation for regulating flap, soiled
Is this possible when you install the manifold with the flaps in the wrong position? I mean wrong position as in flaps may be on the wrong side of the dividers. I believe I had it right the first time, but removed bank 2 manifold again to plug in the vacuum line and electrical connector. I do not remember if I manually put the flaps in the correct position when I installed it the second time.
Is it possible I created an electrical issue somehow?
I just got this car a couple weeks ago. Usually pretty good with cars but this Audi stuff is a little over my head sometimes. Thanks for any help.
