Hi Audi fam,
I just put in new coilovers and I don't think I tightened the top nut enough on the spring/strut assembly because it's clunking and I made the same mistake years ago with my E46. On the S4, there's a rubber cap on either side directly over each wheel well; theoretically, can I undo enough, like the top 4 bolts, and the top control arms, the tie rod, the end link, and maybe take out the bolt to the bottom control arm horseshoe to slide it to get at the top nut through the access holes? I really don't want to take everything out again, though it sounds like almost everything, but getting the shocks into the collar and in place is the biggest hassle.
Has anyone done this before?
Thank you for any advice!
