Results 1 to 8 of 8
    Nov 13 2009
    the OC, SOCAL
    rear camera image just went out today
    hey guys, the rear camera image no longer kicks in when in reverse. i haven't started to work on it yet.
    i wanted to see if anyone else has had the issue what what was your solution to fix yours?
    the sensors still works but no more video feed.
    s3 2015
    Veteran Member Three Rings bakedcorn's Avatar
    Jul 27 2015
    Ontario
    I'm no longer following these forums however I had the app and decided to peruse. I had this issue a couple of times with our A3. It was determined to be a broken wire set for the camera system. Apparently there is no replacement kit I can get from any of the dealers in my area. I then simply crimped all the wires together leveraging barrels and has been working since 2023.
    You need to remove the paneling from the trunk right side. There are some screws and anchors that require removal.
    Good luck.
    Nov 13 2009
    the OC, SOCAL
    you crimped all the wires together leveraging barrels?
    Jul 27 2015
    Ontario
    Quote Originally Posted by 949 View Post
    Apologies for the delay. Yes crimped with the smallest barrel. In my case I was able to cut the barrels to a smaller size. Crimped the copper plus the video cable which was a pain in the ass.
    Side note, not sure why I'm not seeing any alerts about responses here. Apologies again .
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    bakedcorn,
    Very good input, thank you for posting it for others to see.
    -Rod
    (2019 RS 3 owner)
    Rod RS-3
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by bakedcorn View Post
    do you happen to have pics of the barrels your talking about?
    im not sure i follow.
    Jul 27 2015
    Ontario
    I'll have to look for them however today the backup video camera failed for a 4th time in 6 years. I had to start over and this time I soldered each wire including the video cable, the inner copper strands and the shield.
    I'm not sure how Audi pooched this design but it's brutal. I'll have to look at the Honda to see how it's fed through from the trunk door through the rear deck etc.
    If this thing fails again I'll have to design a plan of attack, somehow I'll need to physically remove all the felt tape these wires are wrapped in which makes it extremely difficult.
    Jul 27 2015
    Ontario
    I'm in Ontario and three dealerships could not find the cable from the camera to to video module. It seems the part was available at one point but no longer. They were indicating I would have to purchase the entire rear camera and cable from the front unit to the rear video module. I think it was nearly a grand. I believe the actual part can be purchased from Europe via Kuftech I believe.
    Hope it works out for you and others.
