Two weeks ago my AC stopped working. I did a scan and the code 00256 popped up, sensor for refrigerant pressure/temp sensor. So i replaced the sensor and the AC was working again. I've since ran the AC only two times with no issues. Last time being yesterday on the drive home. Today however it will not kick on again. Its technically possible it could be a bad switch again but I'm guessing not likely. The scan showed the same code 00256 and also fault code 00457, Control Module for Network (J519): No Signal/Communication. It sounds like possibly wiring? What should I be checking, if we assume the sensor is fine?
