Results 1 to 4 of 4
    Sep 06 2013
    Norway
    Audi R8 DSP amp pinout
    Hi!
    Can anyone help with pinout for Audi R8 Standard DSP amp, partnumber 420035223E?
    Thanx😊
    Jul 16 2018
    Atlanta
    I imagine you'll be able to bring it up here: https://cardiagn.com/2008-2015-audi-...ent-locations/
    It may or may not also be documented in the Communication workshop manual: https://cardiagn.com/2007-2009-audi-...iring-diagram/
    Sep 06 2013
    Norway
    Thanx for reply. I found some pinout for R8 wich is what I need now I need to sort out wich cables to pinned in what possition in quadlock for RNS-E. I have so far been able to locate and connect power, gnd, CAN-H, CAN-L and the U14 st DSP (Radio On) signals. They are all correctly connected. From DSP amp connector there are Speaker signal cables for front and rear pinned in pin 24 - 27 and 29 - 32 in the 32 pin DSP amp connector. The same cables are also pinned in connector block that was connected to the factory fitted Clarion unit I am replacing. So I have been doing some trail and error. And when signal cable for front right + and front left plus are connected to pin C3 and and C9 in RNS-E quadlock I get sound, but there is a low buzzing sound when I turn the volume down, and sometimes there are small cracks, spike and distortion to the speakers. Other than that the volume is loud and clear. But there are these noizes in the background that tells me it is not entirely correctly connected, or missing something. I also think there are some mid tweeters in the car at the back just above the safety belt. But no sound from these. The speaker signal wires that runs between the DSP amp and to the stereo harness (RNS-E) just need to pin these correctly and I am golden👍🏻 The wires are colored 24 - White w/black stripe, 25 - Green w/black stripe, 26 - Grey w/white stripe, 27 - Grey with red stripe, 29 - white w/yellow stripe, 30 - Green w/yellow stripe, 31 - white w/blue stripe and 32 - Green w/blue stripe. Need to pin these in correct pin position in RNS-E quadlock connector.
    Jul 16 2018
    Atlanta
    You'll have to be more specific about the vehicle involved. What model year is this vehicle? Ie, MY07-MY12 type 42 original, or MY13-MY15 type 42 facelift? Is this a coupe or convertible? Are you trying to repair or retrofit stuff? What did it come with, what are you trying to install? It appears Audi made no SSP for the type 42.
