Results 1 to 6 of 6
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Plug & Play LIN to CAN MFSW Converter - for B9,8V.5,8Y,8S,R8 Steering Wheel Swaps
    • Enables volume control, backlight control, track forward/back, phone module voice command, & navigation voice guidance buttons on older cars (b6,b7,b8, pre-facelift 8v, 8j, first gen R8)
    • Converts the LIN BUS signal from the newer wheel's buttons to CAN BUS.
    • Completely plug & play, simply replaces the new steering wheel buttons' 4 pin cable. Remove the cable from the right button module's connector, connect the adapter harness, and plug into the airbag/clock spring harness.
    • No Re-pinning or soldering required (beyond what is needed for your airbag harness, depending on your platform)
    Ships from the US. No need to source the other difficult to find adapter modules from Europe that run $150+
    This chip came out about half the size of the others I've seen, mounts to the inside of the wheel with some double sided foam tape.
    $90 Shipped in the USA (for now)
    shoot me a PM with any inquiries regarding installation help, or other required parts for the swap, I can source used MFSW clock springs and steering wheel control modules for cheap if needed.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Senior Member Two Rings catriple's Avatar
    Jan 20 2011
    Minneapolis
    Are these still available?
    [ QUOTE=Gunnarrrrr;15064014]
    [/QUOTE]
    Mar 25 2015
    Placer County
    I’ve got plenty. I also have a couple steering wheels, including some older stuff that doesn't require a conversion module. got single stage and dual stage airbags for both of those as well.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    May 09 2012
    Virginia
    You have a solution for the Cfive yet?
    Jan 20 2011
    Minneapolis
    Quote Originally Posted by Gunnarrrrr View Post
    Sweet. I sent you a PM.
    After all these years I decided to finally buy parts and retrofit heated steering wheel for my q7 Tdi (4L). After looking at the ugly stock wheel and seeing this in ordered a 4M q7 wheel and bag.
    I have to install the clock spring and steering column module first, figure out some coding, but then should be able to plug and play with your adapter.
    LMK how to buy!
    Junior Member Two Rings
    Nov 05 2024
    2007.5 GMC Siera 2500 Duramax, 2011 S4, 522ci Nitrous Jet Boat
    Ventura, CA, United States
    PM'd!
