Results 1 to 13 of 13
Hybrid View
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    CA Smog : Passing test after re-flashing stock tune
    Hi all, I'm working on a tune deal with a tuner who's coming out with B8 ECU and ZF8 tunes. I've had good experience with them in the past on other platforms.
    I live in CA and of course will be subject to biennial smog testing. This ECU tune won't be CARB legal, so if I go this route I would have to flash back to stock (which is a feature of their tuning platform) prior to smog testing.
    Has anybody done similar, where they went from a non-CA-legal tune and reflashed their stock tune to pass smog? I imagine it should pass just fine but don't want to spend money on this just to screw myself over in 2 years.
    Thanks for any feedback!
    2001 Corvette (C5) Z06
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Yes you'll be fine
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by apeck240 View Post
    Yes you'll be fine
    Do you have experience with this in the last 2.5 years? Asking because mid-2021 CA changed their smog test a bit, where they started verifying the ECU/tune's CVN (checksum) value against their database. Changing the tune results in changed CVN, and if it doesn't match one in their database then it's a fail for "tampered" ECU. So mostly I am being ultra-cautious that re-flashing the stock tune will also retain the stock CVN.
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Never been an issue for me here. I smogged at the end of 2021, and again in 2023.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by shaunm82 View Post
    Thanks for the feedback. To clarify, that's flashing back to stock before the smog test?
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Flashing back to stock will work and will also revert the checksum, so it should pass.
    Keep in mind you should drive for 20-30 mins straight after flashing back to a stock tune to produce fuel trim data and also ensure all emission systems have the opportunity to run their functions and pass. At this time, DO NOT go into heavy throttle as your fuel delivery tables are stock and you could also throw an overboost code.
    Sent from my SM-S928U using Audizine Forum mobile app
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by Allowencer View Post
    I appreciate the insight!
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Well I bit the bullet. Here's to tuning I car I wasn't planning to tune LOL (I've tuned every other Audi so why not this one...).
    Mar 15 2009
    CA is not the only state where you may run into the same issue. Same thing here in Virginia. Flashing back to stock is not possible, unless I completely lose my tune as I have an original stasis car #130 with the Revo tune. Revo was the supplier of the tunes for stasis engineering at the time. There is no going back as Stasis it out of business and Revo, if you mention stasis at all, they like many other suppliers for stasis completely, ignore any type of support.
    2009 A4 Black 6MT STaSIS Touring #130
    -STaSIS ECU, cat-back Exhaust, STaSIS rear-sway bar (22mm), STaSIS lowering springs, STaSIS braided brake lines, STaSIS / Carbontech AX6 brake pads (front), STaSIS Monolite wheel (19x9)
    -AWE Tuning Sport Pedal Covers (silver)
    -Black Gloss Grille and Black Gloss US License Panel
    -A4L fog surrounds
    Jun 12 2013
    Quote Originally Posted by kngfisher View Post
    That tune, from what I understand, was a tad more aggressive over stock. You can gain more with a proper tune. None the less, I believe Stasis had to pass e-tests before it could be sold. I could be mistaken though.
    Build Thread
    Mar 15 2009
    The dealership sent my car to get a Dyno once it was done the first time and contacted stasis at the time with their disappointment and revo ended up creating a better more aggressive tune for the 6mt cars and then released the version 2 because of it. The version 2 was a better tune…..either way back then car would pass Va emissions without any issues but a few years back Va and other states now check if the ecu has a tune and just rejects the car even if it produces no more pollution than before. The drive by checker are more forgiving as when a car just drives by it can’t tell if a car has a tune or not unless it is either too old in their view or produces more pollution than allowed. Either way it’s not worth it to be forced back to stock.
    -A4L fog surrounds
    Jun 12 2013
    That's ridiculous. So what are they failing like Rouch Mustangs or anything built by Shelby too? What about SLP? That seems ridiculous.
    Build Thread
    Mar 15 2009
    If it came from the factory then it’s not an issue I guess. In ca and other states “If you're running an EO ECU tune, there's no need to worry about this new policy” however most of us don’t have that option.
    -A4L fog surrounds
