I was wondering (before I look into it too much) if anyone has info/advice on deleting the balance shafts? I ask because balance shafts are a known failure point that can mess up the oiling, leading to damage to expensive new engine parts. The balance shafts spin at twice the RPMs of the crank, and I am building up a motor capable of 7500 RPMs or more, so the balance shafts could be turning as many as 15-16,000 RPMs.
I guess, from what I've read so far, a balance shaft delete requires swapping in an oil pump from a 1.8L or tapping an oil return line and keeping the 2.0L oil pump. It also requires welding closed some areas of the engine. Other than that, I don't know much about it.
I assume the rotating assembly (pistons, rods, crank) would need to be dynamically balanced, which was already planned. What else?
Something else I'd like to know: is the motor under greater threat from potentially failing balance shafts, or from eliminating the balance shafts? And what are potential pitfalls of eliminating the balance shafts?
It seems like a lot of work to delete them, but it also seems less expensive than what results from oil not getting to where it needs to be. As I said, I don't know much about it. It feels like a 6 of one, a half-dozen of the other thing at the moment.
Any thoughts? Dumb idea? Has anyone tried it yet/results?
