Results 1 to 1 of 1
    Junior Member One Ring
    Apr 07 2011
    New York
    RNS-E Issues (Illumination Lights/Night Mode, Automatic Power Off, Etc.)
    My 2005.5 A4 Avant (B7) has an original RNS-E which recently started exhibiting the below collection of malfunctions. Any help in diagnosing the issue would be very much appreciated.
    Malfunctions Observed
    1. When the instrumentation lights are turned on the red illumination lights behind the buttons no longerlight up and the map does not automatically switch to Night mode ("Map scheme" is set to "Auto")
    2. Information (radio station, song name, etc.) is no longer being displayed in the instrument cluster display screen located between the gauges.
    3. The unit no longer automatically powers off when the key is returned to the "ignition off" position.
    RNS-E Configuration
    System SW index: 0020
    HW index: H54
    Map database index: NN0312
    HU/Navi SW version V222017B
    Boot version V220100D
    Audio SW version A2220109-160804
    VAG-COM Scan
    Code:
    Sunday,14,April,2024,14:34:10:61600
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 23.11.0.0 (x64)
    Data version: 20240322 DS351.0
    www.Ross-Tech.com
    VIN: WAUKF68E05A5XXXXX   License Plate:
    Mileage: 189640km-117836mi   Repair Order:
    Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
              67 69 75 76 77
    VIN: WAUKF68E05A5XXXXX   Mileage: 189640km-117836miles
    Address 01: Engine        Labels:. 06F-907-115-AXX.clb
       Part No SW: 8E0 910 115 B    HW: 8E0 907 115 C
       Component: 2.0l R4/4V TFSI     0130
       Revision: --H02---    Serial number:
       Coding: 010C010A190F0120
       Shop #: WSC 08175 444 16721
       VCID: 204428DCF3334391E3-8074
       VINID: 9D195B5862150054450460C80CBD69A47F
    1 Fault Found:
    005489 - Left Engine Mount Solenoid Valve (N144)
                   P1571 - 001 - Short to Plus
                 Freeze Frame:
                        Fault Status: 01100001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 189634 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 680 /min
                        Load: 54.9 %
                        Speed: 0.0 km/h
                        Temperature: 28.0∞C
                        Temperature: 28.0∞C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.684 V
    Readiness: 0000 0000
    Address 02: Auto Trans        Labels: 09L-927-760.lbl
       Part No SW: 8E1 910 156 A    HW: 09L 927 156
       Component: AG6 09L 2,0TFSI USA 0050
       Revision: ˇˇˇˇˇˇˇˇ    Serial number:        ˇˇˇˇˇˇˇ
       Coding: 0000002
       Shop #: WSC 00000 000 00000
       VCID: 254A39C8EC11A6B990-8070
    No fault code found.
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
       Component: ESP8 quattro    H04 0180
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004528
       Shop #: WSC 06325 000 00000
       VCID: 275633C0961DB4A9A2-8072
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 38
                        Time Indication: 0
                 Freeze Frame:
                        Hex Value: 0x00C0
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFFA4
                        Hex Value: 0x00FF
    Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2731
       Coding: 00000
       Shop #: WSC 00000
       VCID: 6CDC0CEC1C7B57F10F-5120
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  USA 0304
       Coding: 11023
       Shop #: WSC 65536
       VCID: 3B7EFFB029950049D6-4B00
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H10 3230
       Revision: 91H10323    Serial number: 0036N000BND-
       Coding: 0032607
       VCID: 3C7CFCAC7F9B0771DF-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 02  0070
       Serial number: 6332DRB401844BACX
       Coding: 00032607
       Subsystem 2 - Serial number: 6342DRB401734A0DM
       Subsystem 3 - Serial number: 6352ARB40050425A8
       Subsystem 4 - Serial number: 6362ARB4005052140
       Subsystem 5 - Serial number: 63729RB400524B34C
       Subsystem 6 - Serial number: 63829RB400524B2FN
    Address 16: Steering wheel        Labels: 8E0-953-549.lbl
       Part No: 8E0 953 549 Q
       Component: Lenks·ulenmodul     0601
       Coding: 02042
       Shop #: WSC 06325
       VCID: 41828D584B796A998C-4B00
    1 Fault Found:
    01304 - Radio
                49-00 - No Communications
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
       Part No SW: 8E0 920 981 N    HW: 8E0 920 981 N
       Component: KOMBI+WFS 4     H12 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0023209
       Shop #: WSC 00999 067 57207
       VCID: 3874E0BC48A32B513B-513C
    2 Faults Found:
    01304 - Radio
                004 - No Signal/Communication
    01300 - Control Module for Navigation with CD-Rom (J401)
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
       Coding: 0023209
       VCID: 3874E0BC48A32B513B-5120
    2 Faults Found:
    01304 - Radio
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       Shop #: WSC 00000
       VCID: 71E21D983B59BA193C-4AE6
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 E    HW: 8E0 035 192 E
       Component: RNS-E US        H54 0020
       Revision:      03S    Serial number: AUZBZ7E1501114
       Coding: 0301617
       VCID: 26483EC49217ADA199-5178
    1 Fault Found:
    01305 - Databus for Infotainment
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 5
                        Fault Frequency: 6
                        Reset counter: 248
                        Time Indication: 15
    Address 46: Central Conv.        Labels:. 8E0-959-433-MAX.clb
       Part No: 8E0 959 433 BT
       Component: Komfortger·t T7B    3232
       Coding: 12092
       Shop #: WSC 06325
       VCID: 040C444C14EBBFB1E7-4B00
       Subsystem 1 - Part No: 8E1959801F
       Component: Tırsteuer.FS BRM 0305
       Subsystem 2 - Part No: 8E1959802E
       Component: Tırsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tırsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tırsteuer.HR BRM 0205
    Address 55: Headlight Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0020
       Revision: 00000001    Serial number:
       Coding: 0000019
       VCID: 26483EC49117ADA199-8072
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH02 0020
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0301617
       VCID: 26483EC49217ADA199-515A
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 7
                        Reset counter: 248
                        Time Indication: 15
    End-------------------------(Elapsed Time: 05:55)--------------------------
